twicer ®   26-Apr-2026 14:10
Recommendation on Onboard Lifting Appliances (Rec.198)
Year: 2026
Author: IACS
Genre: Recommendation, Textbook
Publisher: International Association of Classification Societies (IACS)
Edition: April 2026
Pages count: 12
Description: It is important to highlight that lifting appliances (LA) are inherently hazardous machines, mainly due to their lack of structural redundancy in many components, such as steel wire rope reeving systems. IACS strongly supports the inclusion of lifting appliances in the SOLAS Convention, as this enhances the safety of lifting appliances across the maritime industry by significantly broadening regulatory coverage.
The new SOLAS regulations apply to all new lifting appliances installed on or after 1 January 2026, and to existing lifting appliances and associated loose gear no later than the first renewal survey on or after that date. Regulation II-1/3-13 introduces requirements for classification of standard design and construction, periodic load testing and thorough examinations for both new and existing lifting appliances.
The Maritime Safety Committee at its 107th session adopted (MSC 107/20, paragraph 3.71) amendments to SOLAS Chapter II-1 providing new requirements for onboard lifting appliances and anchor handling winches (SOLAS Chapter II-1, Regulation 3-13) and approved (MSC 107/20, paragraph 3.86.2) related guidelines set out in MSC.1/Circ.1663.
na
Rec-198 Onboard Lifting Appliances_Apr 2026.pdf
Download [551 B]
International Code of Safety for Diving Operations (DIVING Code) - IMO [2023, PDF]
Lifeboat release and retrieval systems – IMO regulations - Lloyds Register & Japan Club [2015, PDF]
SOLAS Requirements and Implementation of the Amendments to SOLAS Regulation V/23 - IMO, IMPA [2025,…
IACS UR E26 Cyber Resilience of Ships and UR E27 Cyber Resilience of On-Board Systems and Equipment…
Recommendation for conducting commissioning testing of Ballast Water Management Systems -…
On board Maintenance and Drills agenda (updated) - Dromon [2022, PDF]
Guidance Notes on Fire-Fighting Systems - ABS [2017, PDF]
Harmonization of GMDSS Requirements for Radio Installations on Board SOLAS Ships - IMO [2023, PDF]
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS [2025, PDF]
The time now is: Today 14:12
