twicer ®   13-May-2024 12:55
Recommendation for conducting commissioning testing of Ballast Water Management Systems
Year: 2024
Author: International Association of Classification Societies (IACS)
Genre: Normative document
Edition: Rec 180 April 2024
Pages count: 20
Description: Rec 180 – Recommendation for conducting commissioning testing of Ballast Water Management Systems – New April 2024. Resolutions.
This recommendation provides guidance for conducting a biological commissioning test of a Ballast Water Management Systems (BWMS) in accordance with IMO BWM.2/Circ.70/rev.1.
The commissioning test shall demonstrate that the BWMS is working properly by verifying that the ballast water discharge is in accordance with the D-2 standard and by an assessment of self-monitoring parameters. These Guidelines have been developed using the best information currently available on procedures, methods, and practices for commissioning testing of BWMS.
na
Rec-180-New-Apr-2024.pdf
Download [1 KB]
IACS Green Book - International Association of Classification Societies (IACS) [2024, PDF]
Ballast Water Treatment and Exchange for Ships - Alexander Olsen, Pamela Ciampolini [2024, PDF/EPUB]
Rules for the Classification Surveys of Ships in Service with Annexes - RMRS [2020, PDF]
Guidelines on Main Propulsion Shafting Alignment - IACS [2025, PDF]
Guidelines For Ballast Water Exchange (G6) - IMO [2017, PDF]
Recommendation on Cyber Resilience (April 2022) - IACS [2022, PDF]
Ballast Water Management Convention and BWMS Code - Supplement - IMO [2022, PDF]
Recommendation on Onboard Lifting Appliances (Rec.198) - IACS [2026, PDF]
Ballast Water Management Convention and BWMS Code with guidelines for implementation - IMO [2018,…
Guidance Notes on Fire-Fighting Systems - ABS [2017, PDF]
The time now is: Today 16:04
