CannonSG2 ®   16-Jun-2016 08:11
HSC 2000 (2008 edition)
Year: 2008
Author: IMO
Publisher: IMO
Edition: 2008
ISBN: 978-92-801-4249-2
Pages count: 318
Description: The Maritime Safety Committee, at its seventy-third session (27 November to 6 December 2000), adopted, by resolution MSC.97(73), the International Code of Safety for High-Speed Craft, 2000 (2000 HSC Code), which had been developed following a thorough revision of the International Code of Safety for High-Speed Craft, 1994 (1994 HSC Code) (resolution MSC.36 (63)), which in turn had been developed following a thorough revision of the Code of Safety for Dynamically Supported Craft (DSC Code) (resolution A.373(X)).
Since then, amendments to the 2000 HSC Code have been adopted by the Maritime Safety Committee by resolutions MSC.175(79) and MSC.222(82), following the provisions in the Code (section 1.15) for a regular review to consider a revision of the existing requirements to take account of new developments in design and technology. The present 2008 edition contains the consolidated current text of the 2000 HSC Code, incorporating the above amendments.
The 1994 HSC Code and the 2000 HSC Code are mandatory under chapter X (Safety measures for high-speed craft) of the 1974 SOLAS Convention and apply to high-speed craft engaged in international voyages the keels of which were laid or which were at a similar stage of construction on or after 1 January 1996 (1994 HSC Code) and 1 July 2002 (2000 HSC Code) respectively. For high-speed craft constructed before 1 January 1996, the DSC Code should be applied.
International Code for Fire Safety Systems (FSS CODE) - IMO [2007, PDF]
POLAR Code (The International Code for Ships Operating in Polar Waters) - KS Gill [2016, PDF]
Procedures for Port State Control, 2019 (Resolution A.1138(31)) - IMO ASSEMBLY [2020, PDF]
IMSBC Code and Supplement (Incorporating Amendment 07-23) 2023 Edition - IMO [2023, PDF]
MARPOL Consolidated Edition - IMO [2011, PDF]
Ballast Water Management Convention and BWMS Code with guidelines for implementation - IMO [2018, PD...
The International Code for the Safe Carriage of Grain in Bulk (International Grain Code) - IMO [1991...
2000 HSC Code International Code of Safety for High-Speed Craft 2021 Edition - Supplement - IMO [202...
International Life-Saving Appliances Code (LSA Code) 2010 Edition (ID982E) - IMO [2010, PDF]
ISM Code and guidelines on implementation of ISM (Electronic Edition) - IMO [2010, PDF]
  • Topic closed
The time now is: Today 19:08
