gillnumil ®   05-Oct-2023 22:43
International Code of Safety for Diving Operations (DIVING Code)
Year: 2023
Author: IMO
Genre: Convention (rules)
Publisher: International Maritime Organization (IMO)
Pages count: 97
Description: The International Maritime Organization has adopted the International Code of Safety for Diving Operations (2023 DIVING Code).
The Maritime Safety Committee, recalling Article 28(b) of the Convention on the International Maritime Organization concerning the functions of the Committee,
Recalling also that the Assembly, when adopting, by resolution A.831(19), the Code of Safety for Diving Systems, 1995 (1995 Diving Code), authorized the Committee to amend the Code as necessary in the light of further developments and experience gained from the implementation of the provisions contained therein,
Recalling further that the Assembly, by resolution A.692(17), adopted Guidelines and specifications for hyperbaric evacuation systems, noting that hyperbaric evacuation systems were of value in certain circumstances for the rescue of divers involved in saturation diving operations where support ships might have to be abandoned,
Recalling that, at its seventy-ninth session, it adopted, by resolution MSC.185(79), amendments to the 1995 Diving Code,
Recognizing the need to ensure that provisions for diving and hyperbaric evacuation operations are kept up to date,
Recognizing also the need to keep the 1995 Diving Code in effect after the adoption of the International Code of Safety for Diving Operations, 2023 (2023 Diving Code), which will apply to ships of not less than 500 gross tonnage that have a diving system installed on or after 1 January 2024,
Bearing in mind that the Assembly, by resolution A.886(21), adopted the Procedure for the adoption of, and amendments to, performance standards and technical specifications, resolving that the function of adopting maritime safety-related performance standards and technical specifications, as well as amendments thereto, shall be performed by the Committee, on behalf of the Organization,
Having considered, at its 107th session, the recommendation made by the Sub-Committee on Ship Systems and Equipment, at its ninth session,
Adopts the International Code of Safety for Diving Operations, 2023 (2023 Diving Code), set out in the annex to the present resolution;
Invites Member States concerned to:
.1 consider the provisions of the 2023 Diving Code as recognized international provisions for the design, construction and survey of diving systems, diving units and hyperbaric evacuation systems; and
.2 take appropriate action to give effect to the 2023 Diving Code.
Goal
The goal of the 2023 Diving Code is, especially where diving safety issues are not adequately addressed by other instruments of the Organization* to:
provide a minimum international standard for the design, construction, installation, and survey of diving systems integrated on ships, floating structures, and MODUs (hereafter referred to as diving platforms) engaged in diving operations;
facilitate safe diving operations from diving platforms and achieve a level of safety equivalent to that required by SOLAS for ships engaged on international voyages; and enable the international movement and safe operation of diving units.
*For example, by SOLAS; the LSA Code, as amended; the MODU Code, as amended; the FSS Code, as amended; the FTP Code, as amended; the Code of Safety for Diving Systems 1995, as amended; and by the Guidelines and specifications for hyperbaric evacuation systems (resolution A.692(17)).
Additional info: Resolution MSC.548(107) was adopted on 8 June 2023 and will enter into force on 1 January 2024.
Chapter 1-5
Appendix 1-3
Procedures for Port State Control, 2019 (Resolution A.1138(31)) - IMO ASSEMBLY [2020, PDF]
ISM Code with guidelines for its implementation - IMO [2018, PDF]
2019 Guidelines for Port State Control under MARPOL Annex VI Chapter 3 (Resolution MEPC.321 (74)) - ...
ISM Code - INTERNATIONAL SAFETY MANAGEMENT CODE with guidelines for its implementation - Internation...
Survey guidelines under the harmonized system of survey and certification (HSSC) - IMO [2025, PDF]
Resolutions: MEPC.314(74); MEPC.316(74); MEPC.317(74) – MARPOL amendments - IMO MEPC [2019, PDF]
International Life-Saving Appliances Code (LSA Code) 2010 Edition (ID982E) - IMO [2010, PDF]
IGF CODE - IMO [2016, PDF]
Rules for Construction and Equipment of Ships Carrying Dangerous Liquid Chemicals in Bulk, 2016 - CC...
Rules for Construction and Equipment of Ships Carrying Liquefied Gases in Bulk 2018 - CCS [2018, PDF...
  • Topic closed
The time now is: Today 18:39
