zxc ®   31-Aug-2025 07:24
In English
I can help you set up a personal SeedBox and configure automatic torrent downloads from our tracker. You only need to rent a VDS via the link and send me the login and password for server console access.
  • Installation cost for VIP: free
  • Installation cost for Release Team: 500 RUB
  • Installation cost for regular users: 1000 RUB
If this is your first time hearing about a SeedBox:
What is a SeedBox and why do you need it?
Seedbox is a remote server specifically configured for downloading and sharing files via torrent (and sometimes other P2P networks).
Simply put, it’s like a “remote computer” that runs 24/7, connected to high-speed internet, and controlled via a web interface.-☑ Why do you need a seedbox?
  • To download and share torrents at high speeds.
  • To avoid overloading your own computer and not keep it running all the time.
  • To hide your real IP address in torrents (your ISP and other peers only see the SeedBox IP).
  • To have constant access to files from anywhere in the world 24/7 and download them later conveniently (via FTP, HTTP, SFTP, WebDAV).
-☑ Advantages of a seedbox over regular home downloading:
  • High speed – Seedbox connections are usually 1–10 Gbps, so downloads and uploads are much faster than most home connections.
  • 24/7 operation – The SeedBox is always online, your torrents continue seeding even when your computer is off.
  • Anonymity protection – your real IP stays hidden, which is important if your ISP or laws limit torrents.
  • Tracker ratio support – many private trackers require you to “upload more than you download.” With a SeedBox, this is easy: you upload quickly and improve your ratio.
  • Convenient access – you can download completed files from the SeedBox anytime, on your phone or another computer.
  • Fewer ISP issues – some ISPs throttle speed or block torrents. A SeedBox bypasses this.
-☑ How it works in practice:
  • You access the web panel (usually similar to uTorrent or Transmission).
  • Add a torrent file or magnet link.
  • The SeedBox downloads and seeds the file automatically.
  • When you want, download the completed file to your computer or stream it online.
☑ Can automatic torrent downloading be configured?
Recommended locations that are torrent-friendly: Finland (Helsinki), Netherlands (Dronten), Germany (Frankfurt)
Preferred OS: Debian 12
Link to website 62yun.ru
CPURAMDiskData CenterPortOSPrice (₽/mo)Price (€/mo)
1×2.3GHz Intel Xeon E5-2697v41 GB DDR410GB NVMeCreanova DC1Gbit/sLinux249₽3 €
2×2.3GHz Intel Xeon E5-2697v42 GB DDR4500GB HDDCreanova DC1Gbit/sLinux, Windows349₽4 €
2×2.3GHz Intel Xeon E5-2697v42 GB DDR440GB NVMeCreanova DC1Gbit/sLinux, Windows539₽6 €
1×2.3GHz Intel Xeon E5-2697v41 GB DDR41TB HDDCreanova DC1Gbit/sLinux599₽6 €
2×2.3GHz Intel Xeon E5-2697v42 GB DDR42TB HDDCreanova DC1Gbit/sLinux, Windows799₽8 €
4×2.3GHz Intel Xeon E5-2697v46 GB DDR4100GB NVMeCreanova DC1Gbit/sLinux, Windows859₽9 €
4×2.3GHz Intel Xeon E5-2697v44 GB DDR44TB HDDCreanova DC1Gbit/sLinux, Windows999₽11 €
4×2.3GHz Intel Xeon E5-2697v432 GB DDR4250GB NVMeCreanova DC1Gbit/sLinux, Windows1199₽13 €
Which to choose for a SeedBox: HDD or NVMe?
When renting a SeedBox (VPS/VDS for torrents), one of the main questions is which disk type to choose. At first glance, the difference is only in price, but in practice there are important nuances.-☑ HDD (Hard Disk)
  • Large capacity at low cost (1–4 TB for an affordable price).
  • Suitable for long-term seeding when read/write speed is not critical.
  • Excellent choice if you store many torrents and want to download/share archives, movies, games, etc.
Downside: low speed and low IOPS (few input/output operations per second). If many torrents are active simultaneously, the disk may slow down.
-☑ NVMe (Next-gen SSD)
  • Very high read/write speed (tens of times faster than HDD).
  • High IOPS – you can handle many more active torrents simultaneously without speed drops.
  • Instant file access and high performance even with many connected peers.
  • Minimal latency – especially useful for small files or when fast data upload is important.
Downside: smaller capacity for the same price (e.g., instead of 1TB HDD, you get only 100–250GB NVMe).
-☑ What to choose?
  • HDD – if you need large capacity and plan to store many torrents (movies, series, archives). Suitable for long-term seeding.
  • NVMe – if you need maximum speed, high IOPS, quickly increase tracker RATIO, and handle hundreds/thousands of active torrents without performance loss.
-☑ Optimal choice
— For a “super seeder” who wants many files online → HDD
— For active seeding on trackers with many peers and focus on speed → NVMe
The best choice depends on your budget and goals: need capacity → HDD, need speed and more active torrents → NVMe.
I know Linux and want to configure everything myself
Then this guide is for you
Hidden text: ** You do not have enough reputation to view the hidden text (required 100) **
-To get the PHP script and configure automatic torrent downloads via RSS, contact zxc
По-русски
Помогу с установкой персонального СИДбокса и настрою автоматическое скачивание торрентов с нашего трекера. От вас требуется арендовать VDS по ссылке и прислать мне логин и пароль для доступа к консоли сервера.
  • Стоимость установки для VIP - бесплатно
  • Стоимость установки для Релизеров - 500 руб.
  • Стоимость установки для обычных пользователей - 1000 руб.
Если вы впервые слышите, что такое SeedBox:
Что такое SeedBox и зачем он вам нужен?
Seedbox — это удалённый сервер, специально настроенный для скачивания и раздачи файлов через торрент (а также иногда через другие P2P-сети).
Проще говоря, это как «удалённый компьютер», который работает круглосуточно, подключён к быстрому интернету и управляется через веб-интерфейс.-☑ Зачем нужен seedbox?
  • Чтобы качать и раздавать торренты на высокой скорости.
  • Чтобы не нагружать свой компьютер и не держать его постоянно включённым.
  • Чтобы не светить свой реальный IP-адрес в торрентах (ваш провайдер и соседи по раздаче видят только IP сидбокса).
  • Чтобы иметь постоянный доступ к файлам из любой точки мира 24/7 и скачивать их потом себе удобным способом (через FTP, HTTP, SFTP, WebDAV).
-☑ Преимущества seedbox перед обычным домашним скачиванием:
  • Высокая скорость – каналы сидбоксов обычно 1–10 Гбит/с, поэтому скачивание и раздача происходят значительно быстрее, чем у большинства домашних соединений.
  • Круглосуточная работа – сидбокс всегда онлайн, ваши торренты продолжают раздаваться даже когда ваш компьютер выключен.
  • Защита анонимности – ваш настоящий IP остаётся скрытым, что особенно важно, если провайдер или законы ограничивают торренты.
  • Поддержка рейтинга на трекерах – многие приватные трекеры требуют «отдавать больше, чем качаешь». С сидбоксом это легко: вы быстро раздаёте и улучшаете свой рейтинг.
  • Удобный доступ – вы можете качать готовый файл с сидбокса в любое время, хоть на телефон, хоть на другой компьютер.
  • Меньше проблем с провайдером – некоторые интернет-провайдеры режут скорость или блокируют торренты. С сидбоксом это обходится.
☑ Как это работает на практике:
  • Вы заходите в веб-панель (обычно похожа на uTorrent или Transmission).
  • Добавляете торрент-файл или magnet-ссылку.
  • Сидбокс сам скачивает и раздаёт файл.
  • Когда захотите, скачиваете готовый файл на свой компьютер или смотрите его прямо онлайн (стриминг).
☑ Можно ли настроить автоматическое скачивание торрентов
Рекомендуемые локации лояльные к торрентам: Финляндия (Хельсинки), Нидерланды (Дронтен), Германия(Франкфурт)
Предпочтительная ОС: Debian 12
Ссылка на сайт 62yun.ru
CPURAMДискДата-ЦентрыПортОСЦена в мес.
1×2.3GHz Intel Xeon E5-2697v41 GB DDR410GB NVMeCreanova DC1Gbit/sLinux249₽/мес
2×2.3GHz Intel Xeon E5-2697v42 GB DDR4500GB HDDCreanova DC1Gbit/sLinux, Windows349₽/мес
2×2.3GHz Intel Xeon E5-2697v42 GB DDR440GB NVMeCreanova DC1Gbit/sLinux, Windows539₽/мес
1×2.3GHz Intel Xeon E5-2697v41 GB DDR41TB HDDCreanova DC1Gbit/sLinux599₽/мес
2×2.3GHz Intel Xeon E5-2697v42 GB DDR42TB HDDCreanova DC1Gbit/sLinux, Windows799₽/мес
4×2.3GHz Intel Xeon E5-2697v46 GB DDR4100GB NVMeCreanova DC1Gbit/sLinux, Windows859₽/мес
4×2.3GHz Intel Xeon E5-2697v44 GB DDR44TB HDDCreanova DC1Gbit/sLinux, Windows999₽/мес
4×2.3GHz Intel Xeon E5-2697v432 GB DDR4250GB NVMeCreanova DC1Gbit/sLinux, Windows1199₽/мес
Что выбрать для сидбокса: HDD или NVMe?
Когда вы арендуете сидбокс (VPS/VDS для торрентов), один из главных вопросов — какой тип диска выбрать. На первый взгляд разница только в цене, но на практике есть важные нюансы.-☑ HDD (жёсткий диск)
  • Большой объём по низкой цене (можно взять 1–4 TB за доступные деньги).
  • Подходит для долгих "сидов" (раздач), когда скорость записи и чтения не так критична.
  • Отличный выбор, если вы храните много торрентов и хотите качать/раздавать архивы, фильмы, игры и т.д.
Минус: низкая скорость и низкий IOPS (мало операций ввода-вывода в секунду). Если одновременно много активных торрентов — диск начинает "тормозить".
-☑ NVMe (SSD нового поколения)
  • Очень высокая скорость чтения/записи (в десятки раз быстрее HDD).
  • Высокий IOPS — значит, можно держать намного больше активных торрентов одновременно, без просадок в скорости.
  • Моментальный доступ к файлам и высокая производительность даже при большом количестве подключённых пиров.
  • Минимальные задержки — особенно полезно при работе с маленькими файлами или когда важно быстро "отдавать" данные другим пользователям.
Минус: меньше объём за те же деньги (например, вместо 1TB HDD вы получите только 100–250GB NVMe).
-☑ Что выбрать?
  • HDD — если вам важен большой объём и вы планируете хранить много торрентов (фильмы, сериалы, архивы). Подходит для долгосрочных раздач.
  • NVMe — если вам важна максимальная скорость, высокий IOPS, быстрое поднятие RATIO на трекере и возможность держать сотни/тысячи активных торрентов без потери производительности.
-☑ Оптимальный вариант
— Для "супер сидера", который хочет держать много файлов в онлайне → HDD.
— Для активной раздачи на трекерах с большим количеством пиров и акцентом на скорость → NVMe.
Лучшее решение зависит от вашего бюджета и целей: нужен объём — берите HDD, нужна скорость и больше активных торрентов — NVMe.
Я разбираюсь в Linux и хочу все настроить сам
Тогда эта инструкция для вас
-Для получения php скрипта и настройке автоматического скачивания торрентов по RSS обратитесь к zxc
Автоматическая загрузка торрентов по RSS (SEEDBOX)
Что такое SeedBox?
DOWNLOAD LIMIT
BOCA Suite v.2.2.0.3 - AVEVA [2018]
MaxSea v12.6.4.1 + CM93v3 Nov-2019 charts (Windows 10 VirtualBox) - MaxSea [2019]
The time now is: Today 17:04
