twicer ®   13-Feb-2025 17:06
Cathodic Protection of Offshore Structures
Year: 2025
Author: Alexander Arnfinn Olsen
Genre: Textbook
Publisher: Springer
Edition: 1st
ISBN: 978-3-031-77581-9
Pages count: 69
Description: Cathodic protection, when used in conjunction with protective coatings, is a common method used to protect immersed parts of steel surfaces from corrosion. This text on Cathodic Protection of Offshore Structures offers detailed recommendations on cathodic protection for offshore structures. Traditional seagoing vessels dock at regular intervals, but offshore structures such as Floating Production Storage and Offloading structures (FPSOs) are stationary and are in continuous operation for prolonged periods of time.
Therefore, the design of the corrosion protection for a 15-year or longer service life of a floating offshore structure requires special consideration. Some Floating Production Installations (FPIs) have hull designs similar to oil tankers, especially those converted from oil tankers. Others are designed and built as floating production platforms. Cathodic protection systems are to consider the structure to be protected as a whole as well as individual components which are attached to the structure.
The information presented in text is intended solely to assist the reader in the methodologies and/or techniques discussed. This text does not and cannot replace the analysis and/or advice of a qualified professional. It is the responsibility of the reader to perform their own assessment and obtain professional advice. Information contained in this text is considered to be pertinent at the time of publication but may be invalidated as a result of subsequent legislation, regulations, standards, methods, and/or more updated information and the reader assumes full responsibility for compliance.
Cathodic Protection of Offshore Structures.pdf
Download [1 KB]
Marine Corrosion and Cathodic Protection - Chris Googan [2022, PDF]
Impress Current Cathodic Protection System Manual - HWASEUNG R&A (Wilson Walton Korea) [2012, PDF]
Guide for Modified Tank Entry Program - American Bureau of Shipping (ABS) [2025, PDF]
Modified Tank Entry Program-v1 - ABS [2025, PDF]
Cathodic Corrosion Protection Systems - A Guide for Oil and Gas Industries - A Guide for Oil and Gas...
Accidental Load Analysis and Design for Offshore Structures - Alexander Arnfinn [2024, PDF]
Marine and Offshore Corrosion - Kenneth A. Chandler [1985, PDF]
Marine Corrosion of Stainless Steels - Chlorination and Microbial Effects - Working Party on Marine ...
The time now is: Today 03:46
