twicer ®   12-May-2024 19:45
FindaportCD Oracle VirtualBox
Year: 2024
Version: Findaport ver 1.7 (March, 2024) / VirtuarBox ver 17
Developer: Oracle and LR OneOcean
Platform: Windows/MacOS
64-bit OS compatibility: yes
System Requirements: In order to run VirtualBox on your machine, you need:
Hardware: Reasonably powerful x86 hardware. Any recent Intel or AMD processor should do.
OS: Presently, runs on Windows, Linux, macOS, and Solaris hosts
Memory: at least 2 GB of RAM, recommended
Hard disk: While VirtualBox itself is very lean (a typical installation will only need about 30 MB of hard disk space), the virtual machines will require fairly huge files on disk to represent their own hard disk storage. So, to install Windows 8, for example, you will need a file that will easily grow to several 10 GB in size.
installed Host machine spec:
OS: Windows 7 Pro (32-bit) activated
Processors: 2 Core (- your guest)
Hard Disk: 16 GbRAM: 2048 Mb (- your guest)
Video: VBoxCVGA 256 Mb
Localization: English
Crack: Not needed
Description: VirtualBox is a general-purpose full virtualizer for x86 hardware, targeted at server, desktop and embedded use. VirtualBox is a powerful x86 and AMD64/Intel64 virtualization product for enterprise as well as home use. Not only is VirtualBox an extremely feature rich, high performance product for enterprise customers.
FindaportCD is Offline access to port information in a digital format. Ideal for vessels with restricted internet access, looking for access to port data digitally.
Access to the latest port information is essential for mariners when planning and executing a port call and enabling safe and efficient access to marine facilities. Findaport.com is an online port information website that enables subscribers to access the maritime industry's most comprehensive port information available. It is owned and operated by OneOcean Group, leading providers of maritime navigation and compliance solutions.
Information in database is researched and updated daily by a dedicated team of editors using only authenticated sources such as port authorities, agents, and operators. You can therefore be safe in the knowledge that you are accessing the most up-to-date information available to the maritime industry on the ports you visit.
Discover in-depth information on port facilities around the world. You will find details about the cargo accepted and facilities and equipment available at terminals and even individual berths.
Two editions of FindaportCD are available:
- FindaportCD: Standard - access to all our port information irrespective of cargo type
- FindaportCD: Tanker - tanker specific information onlyA trial is a lot of times the full completed
A trial is a lot of times the full completed "game" whereas a demo may be a a part of a full "game" or may not represent the final state of the "game"!
Plus installed on VirtualMachine:
- Admiralty TotalTide ver 7.6.1.0
- PortToPort Desktop Marine Distance Tables ver 5.7.90.0
see Screenshots for more details
How to use
1. install VirtualBox
2. install VirtualBox Extension Pack
3. unpack FindaportCD.rar to any location
4. add FindaportCD.vbox VM to VirtualBox
5. run guest OS - Windows. don't run findaport yet!!!
6. in order to prevent VirtualBox Guest Syncing Time with Host run the following command:
Windows: open CMD.exe as Administrator -->
cd C:\Program Files\Oracle\VirtualBox
VBoxManage setextradata "FindaportCD" "VBoxInternal/Devices/VMMDev/0/Config/GetHostTimeDisabled" 1
MacOs: terminal command -->
The guest will now NOT sync date & time with the host!
* perhaps it will be necessary to do the same every time you start a virtual machine before starting the Findaport ??
7. now change Guest OS system time and date to: 01-04-2024 00:00 !!
8. run Findaport
9. eternal trial. enjoy!
* if for any reason the message “Trial version has expired” appears OR any trouble with VirtualMachine, simply restore the snapshot again and follow the instructions starting from step 5.
in fact, everything is not difficult, considering the cost of the product
Download [13 KB]
FindaportCD FindaportCD v.1.7 March Edition - Lloyd’s Register OneOcean (LR OneOcean) [2025]
MaxSea v12.6.4.1 + CM93v3 Nov-2019 charts (Windows 10 VirtualBox) - MaxSea [2019]
One Ocean v.10.2.8 - ChartCo [2022]
ADMIRALTY Digital Catalogue (ADC) v.1.8.8 - UKHO [2026]
PortToPort Desktop | Marine Distance Tables v.6.1.26.0 - CherSoft Ltd [2025]
DNV Software Sesam Marine 2013 v.14 (sept 2019) - DNV [2019]
The time now is: Today 16:53
