twicer ®   30-Jan-2024 11:35
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments
Year: 2023
Author: MCA
Edition: Rev 05.23
Pages count: 151
Description: The basis text in this document is extracted from the SOLAS Consolidated Edition 2014 which incorporates all SOLAS amendments in effect from I July 2014 most notably, from the damage stability aspect, the December 2006 Annex 2 amendments, adopted by IMO resolution MSC.216(82), which entered into force for passenger ships and dry cargo ships with keels laid on or after 1 January 2009.
Commonly known as the SOLAS 2009 amendments, MSC.216(82) substantially revised SOLAS90 Part 1 Chapter II-1 Parts A (General), B (Subdivision and Stability) and B-1 (Subdivision and Damage Stability of Cargo Ships). The amendments resulted in Chapter II-1 being re-organised and revised.
Additional info:
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2020, PDF]
Author: MCA | Year: 2020 | Language: english | Format: PDF | Quality: eBook | Pages count: 144
Open released by twicer
MSIS42_Damage_Stability_R05.23_002_.pdf
Download [6 KB]
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2020,…
INSTRUCTIONS FOR THE GUIDANCE OF SURVEYORS ON INTACT STABILITY IMO 2008 CODE & Explanatory Notes-…
Instructions for the Guidance of Surveyors on International Load Line - MCA [2020, PDF]
Instructions for the Guidance of Surveyors on Intact Stability IMO 2008 IS CODE - MCA [2020, PDF]
International Code for Application of Fire Test Procedures (FTP CODE) - IMO [2012, PDF]
SOLAS Consolidated Edition 2020 - IMO [2020, PDF]
SOLAS Consolidated Edition - IMO [2009, PDF]
The time now is: Today 17:03
