twicer ®   01-May-2021 14:07
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments
Year: 2020
Author: MCA
Pages count: 144
Description: INTRODUCTION AND HISTORICAL BACKGROUND
INSTRUCTIONS FOR THE GUIDANCE OF SURVEYORS ON DAMAGE STABILITY SOLAS 2020 AMENDMENTS
With Explanatory Notes MSIS42 Rev 05.2020
The basis text in this document is extracted from the SOLAS Consolidated Edition 2014 which incorporates all SOLAS amendments in effect from I July 2014 most notably, from the damage stability aspect, the December 2006 Annex 2 amendments, adopted by IMO resolution MSC.216(82), which entered into force for passenger ships and dry cargo ships with keels laid on or after 1 January 2009.
Commonly known as the SOLAS 2009 amendments, MSC.216(82) substantially revised SOLAS90 Part 1 Chapter II-1 Parts A (General), B (Subdivision and Stability) and B-1 (Subdivision and Damage Stability of Cargo Ships). The amendments resulted in Chapter II-1 being re-organised and revised.
Some MCA Guidance Notes are included, mostly extracted from the current Instructions to Surveyors for Passenger Ships. Work is still in progress on these at the time of writing (May 2020), including guidance of our interpretation of regulations in SOLAS which include phrases such as “to the satisfaction of the Administration”.
Damage_Stability MSIS42.pdf
Download [4 KB]
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2023,…
Instructions for the Guidance of Surveyors on Intact Stability IMO 2008 IS CODE - MCA [2020, PDF]
INSTRUCTIONS FOR THE GUIDANCE OF SURVEYORS ON INTACT STABILITY IMO 2008 CODE & Explanatory Notes-…
Instructions for the Guidance of Surveyors on International Load Line - MCA [2020, PDF]
SOLAS Consolidated Edition 2020 - IMO [2020, PDF]
International Code for Application of Fire Test Procedures (FTP CODE) - IMO [2012, PDF]
SOLAS Consolidated Edition - IMO [2009, PDF]
The time now is: Today 15:54
