gillnumil ®   22-Jun-2019 21:19
International Code For The Construction and Equipment of Ships Carrying Liquefied Gases in Bulk (IGC Code)
Year: 2016
Author: IMO
Genre: Convention (rules)
Publisher: IMO
Edition: 2nd
ISBN: 978-92-801-1631-1
Pages count: 183
Description: The new 2016 edition of the IGC Code incorporates the amendments adopted by the MSC at its ninety-third session (May 2014) by resolution MSC.370(93). These amendments, which entered into force on 1 January 2016, consist of a complete replacement text of the IGC Code.
Unless expressly provided otherwise, the requirements of the IGC Code, as amended by resolution MSC.370(93), apply to ships whose keels are laid, or which are at a similar stage of construction, on or after 1 July 2016.
For ships constructed on or after 1 July 1986 and before 1 July 2016, unless expressly provided otherwise, the Administration shall ensure that such ships comply with the requirements which are applicable under the IGC Code, as adopted by resolution MSC.5(48) and as amended by resolutions MSC.17(58), MSC.30(61), MSC.32(63), MSC.59(67), MSC.103(73), MSC.177(79) and MSC.220(82).
Additional info: The purpose of this Code is to provide an international standard for the safe carriage, by sea in bulk, of liquefied gases and certain other substances that are listed in chapter 19. Through consideration of the products carried, it prescribes the design and construction standards of the ships involved and the equipment they should carry to minimize the risk to the ship, its crew and the environment.
International Code For The Construction and Equipment of Ships Carrying Liquefied Gases in Bulk (IGC...
IGC Code (International Code for the Construction and Equipment of Ships Carrying Liquefied Gases in...
Rules for Construction and Equipment of Ships Carrying Liquefied Gases in Bulk 2018 - CCS [2018, PDF...
KR Pt.7 Ch.5 Ships carrying Liquefied gases, Ch.6 Dangerous Chemicals 2022 - KR [2022, PDF]
Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (BCH Code) - I...
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2023, PD...
Instructions for the Guidance of Surveyors on Damage Stability SOLAS 2020 Amendments - MCA [2020, PD...
Guide for liquefied Gas Carriers with Independent tanks November 2019 - ABS [2019, PDF]
Requirements for Liquified Hydrogen Carriers - ABS [2023, PDF]
  • Topic closed
The time now is: Today 12:18
