Spirit35 ®   18-Sep-2023 11:50
Alfa Laval Clarifier and Purifier for Lube Oil System
Year: 2017
Genre: Video for Marine Engineers
Playtime: 39mins.
Quality: WEB-DL
Format: MP4
Video: 36.7 MB / 480x360 / 4:3
Audio: 320Kbps / 48.0 KHz
Description: Explanation of the ALCAP fuel oil system, including its components, emergency stop buttons, heat back power unit, EPC separator, pump starter, EPC 400 supervision and controller, heater header tank, operating water, and conditioning water. The EPC 400 is a microprocessor-based supervision and control unit for the separator, with a temperature controller. The separator has a flow indicator for monitoring oil flow, and the system recirculates oil away in abnormal situations. The oil should be of low viscosity for better separation. A positive displacement pump is recommended for heavy fuel oil feed.
Alfa Laval Clarifier and Purifier for Lube Oil System.zip
Download [8 KB]
Alfa Laval Clarifier and Purifier for Fuel Oil System [2017, MP4]
Alfa Laval Purifier Operational (PX) [19XX, MP4]
Сепараторы и опреснители Alfa Laval / Separators and Evaporators Alfa-Laval [PDF, MPEG, XLS]
The time now is: Today 15:13
