princimarfaith ®   06-Sep-2013 18:42
SAACKE BOILER CD MANUAL
Year: 2006
Format: HTML
Description: Operating Instructions „to be placed in boiler house“ B
for firing plants with
More...
Rotary Cup Burners for heavy or light fuel oil (laminated) 0-0001-4078/02
Oil firing plants for marine plants (laminated) 0-0001-4210/02
Instructions for manual/emergency operation (laminated) 1-8828-4029-02
General Instructions for SAACKE Burner System B
with Rotary Cup Burners for heavy fuel oil 0-0001-4107/02
with Rotary Cup Burners for light fuel oil 0-0001-4061/02
with Rotary Cup Burners for heavy fuel oil, equipped 0-0001-4071/02
with start-up system for light oil
General documentation B
Viscosity Temperature Chart 0-0001-7514/31
Operation Manual Duoblockburner SKV 15 - 400 BA-SKV-15-400-02e
Main Drawings of the Firing Plant 0
Burner Assembly Drawing N048805 BA
Parts list N 048805/2HR
Spare Parts List for Marine Installation Chapter 0 / Parts List
Three-Phase Motor 7AA 132 (Design B3) 1.3.1 + 2.3.1 1
Technical Description 700105
Technic, Maintenance, Operation 700116
Pressure Monitor Primary Air DL 150 A 1.3.1 + 2.3.1 1
Pressure Monitor Combustion Air DL 150 A 1.3.1 + 2.3.1 1
Data sheet SMS 4-0003-0002//2
Drawing 2-6386-297107/1
Structural Parts List 2-6386-297107
Drawing 2-6374-305860/2
Parts List 2-6375-305860
Igniter ZLE 52 c / 44 1.3.1 + 2.3.1 1
Data and Description sheet 2-3301-1305/02
Exploded view drawing 2-3301-7088/31
Structural Parts List 2-3301-296513
Ignition Valves 1.3.1 + 2.3.1 1
Drawing 2-3328-530192/1
Structural parts list 2-3328-530192
Ignition Transformer ZE/ZM 1.3.1 + 2.3.1 1
Data sheet SMS 3-0003-0026//2
2/2-Way-Magnetic Valve 9500295.3205.230.50 1.3.1 + 2.3.1 1
Data sheet SMS 3-0003-0017//2
Electromagnetic Valve “NOP” 122 K 8321 1.3.1 + 2.3.1 1
Data sheet SMS 3-0003-0018//2
Ignition oil pressure gauge - Type 111.16 1.3.1 + 2.3.1 1
Data sheet SMS 3-0003-0015//2
Ignition oil pump PZHDS 30 1.4.3 1
Data sheet SMS 3-0003-0007//2b
Parts List 1-3851-279060
Drive Motor 7AA 63M (Design B5) 1.4.3 1
Technical Description 700104
Technic / Maintenance / Operation Instructions 700116
Double Temperature Switch ATHS-22 1.3.1 + 2.3.1 2.1
Data sheet SMS 3-0003-0009//2
Shut-off Valve DIN 16270 1.3.1 + 2.3.1 2.1
Technical Data Sheet 700417 700930
Drive Motor HD 60 D 2 1.3.1 + 2.3.1 2.1
Data sheet SMS 3-0003-0019//2
Electromagnetic Valve ESV 12 1.3.1 + 2.3.1 2.1
Data sheet SMS 3-0003-0024//2
Data and Description sheet 1-3638-1204/02
Exploded View drawing 1-3638-7026/31
Structural Parts List 1-3638-203753
Structural and Operational Description 1-3638-3074/32
Maintenance Instructions 1-3638-5049/02
Instructions for Repairs 1-3638-5012/02
Oil Flow Meter VZO 20S RC 1.3.1 + 2.3.1 2.1
Technical Information 700232
Instructions for Installing VD 4-412 / Aqua metro
Operation Instructions 700234
Maintenance 700101
Manual Rapid Shut-off Valve K 84 (DN 15) 1.3.1 + 2.3.1 2.1
Description SMS 3-0003-0021//2
Instrument assembly unit 1.3.1 + 2.3.1 2.1
Drawing 2-6223-338191/3
Structural Parts List 2-6223-338191
Two-Point Temperature Monitor 1.3.1 + 2.3.1 2.1
Type : AMV 2-2
Data sheet SMS 3-0003-0023//2
Inclined Strainer (R ½“, DN 15) 1.3.1 + 2.3.1 2.1
Data and Description sheet SF 335 / Krombach
Pressure Monitor DWR 6-203 1.3.1 + 2.3.1 2.1
Data sheet SMS 3-0003-0010//2
Fuel Oil pressure gauge Type 111.10 1.3.1 + 2.3.1 2.1
Data sheet SMS 3-0003-0016//2
Compound Regulator VRK 8 “Index E” 1.3.1 + 2.3.1 2.1
Data and Description sheet 1-3500-1183/02
Exploded View drawing 1-3500-7041/31
Structural Parts List 195265
Operating and Maintenance Instructions 1-3500-4109/02
Fuel oil pressure control valve Type HS 25 N 1.3.3 + 2.3.3 2.1
Data sheet SMS 3-0003-0092//2
Fuel oil pressure control valve Type HS 25 N 1.3.4 + 2.3.4 2.1
Data sheet SMS 3-0003-0093//2
Change over valve “MDO/HFO” 1.3.5 + 2.3.5 2.1
Data sheet SMS 3-0003-0094//2
Circulation flow regulation valve 1.3.6 + 2.3.6 2.1
Drawing 2-3935-194533
Expansion vessel for Ignition oil line 1.3.7 + 2.3.7 2.1
Data sheet SMS 3-0003-0005//2
Combustion Air Fan L 180 portal 1.3.2 + 2.3.2 3
Data and Description sheet VENTA
Fuel Oil Supply System 1.3.1 4
Technical Description MAS
Fuel Oil pressure control valve 1.3.1 4
Data sheet SMS 3-0004-0017//2
Windbox Wiring 1.5 + 2.4 5
Wiring Diagram 0-9008-048805-18
Wiring Diagram 0-9008-048805-28
Port Side Boiler 1.5 + 2.4 5
Wiring Diagram 0-9002-048805-10
Star Board Boiler 1.5 + 2.4 5
Wiring Diagram 0-9002- 048805-20
Remote pressure indicator 1.5.3 + 2.4.2 5
Data sheet SMS 3-0005-0004//2
Remote level indicator 1.5.4 + 2.4.3 5
Data sheet SMS 3-0005-0005//2
Flame Detector FLUS 06 1.3.1 + 2.3.1 6
(With Flame Scanner FLS09 mounted on burner)
Technical Handbook 1-8254-8011/02
Service-/Initial Operation 1-8254-8015/02
Emergency Operation System NB 02 1.3.1 + 2.3.1 8
Data and Description sheet 1-8828-4029/02
Strap-On Temperature Controller 1.3.1 + 2.3.1 9
Type: RAK 582.4 / 3726 M
Data sheet SMS 3-0003-00-22//2
SAACKE boiler cd.rar
Download [10 KB]
princimarfaith ®   06-Sep-2013 18:50
Уважаемые Админы, не судите строго Пират и проверьте файл - скачивается или нет?
zxc   06-Sep-2013 19:14
Пошел кач. Вот только раздавать нужно не архив, а папку. Спасибо
snk1   13-Jan-2014 14:32
dear Sir,
Pls. guide me as I'm unable to view or download the file.
Thanks & regds.
Megadave_4x4   12-Oct-2022 03:49
Dear Sir;
Please, could you share the download link of the Saacke boiler manual.
best Regards
CD-09-1 BOILER KAWASAKI UME 65/52 (Maritime Electronic Library) - ERMO83 [2011, PDF]
The time now is: Today 15:02
