pfsv ®   01-Jul-2022 02:30
Jetty Maintenance and Inspection Guide
Year: 2008
Author: SIGTTO / OCIMF
Edition: 2008
ISBN: 9781856093439
Quality: OCR without errors
Pages count: 118
Description: This guide provides information on effective maintenance of critical items of equipment for both oil and liquefied gas terminal jetties. It advises on possible failure modes for each item of equipment and also discusses proactive and reactive maintenance strategies.
Reliable equipment at the jetty is vital for safe transfer of cargo between the ship and shore.
Maintenance of this equipment is particularly important because of the harsh environmental conditions often experienced.
This guide provides information on the basic function, failure, inspection, maintenance and repair of all the key equipment items and systems. It is not intended to provide guidance on safety management procedures or to replace the manufacturers’ instruction manuals. However, it is designed to provide a description of a typical jetty and the likely faults that may occur if maintenance work is not carried out regularly.
Jetty Maintenance and Inspection Guide.pdf
Download [14 KB]
Liquefied Petroleum Gas Sampling Procedures - SIGTTO [2010, PDF]
Safety Critical Equipment and Spare Parts Guidance - OCIMF [2026, PDF]
Detection and Reporting of Fugitive Methane Emissions from LNG Carriers - SIGTTO [2022, PDF]
Inspection Guidelines For Ships Carrying Liquefied Gases In Bulk - SIGTTO [1998, PDF]
Safety Critical Equipment Guidance 2026 - OCIMF [2026, PDF]
Recommendations for Manifolds for Refrigerated Liquefied Natural Gas Carriers (LNG) - OCIMF [1994, P...
Recommendations For Relief Valves On Gas Carriers - SIGTTO [2020, PDF]
LNG Transfer Arms and Manifold Draining, Purging and Disconnection Procedure - SIGTTO [2012, PDF]
An Introduction to the Design and Maintenance of Cargo System Pressure Relief Valves on Board Gas Ca...
The time now is: Today 13:43
