gillnumil ®   28-Sep-2018 11:03
An Introduction to the Design and Maintenance of Cargo System Pressure Relief Valves on Board Gas Carriers
Year: 2014
Author: SIGTTO
Publisher: Witherby Publishing Group Ltd
Edition: 2nd
ISBN: 978-1-85609-163-3
Pages count: 34
Description: This book was written following an incident in 1992 that involved failure of a relief valve when a semi-pressurised LPG carrier was being loaded. The cargo being loaded was propane, and the pressure relief valves PRVs were set to operate at 11 bar gauge. During the final stages of loading at a pressure of 7 bar gauge, one of the pressure relief valves fitted to a cargo tank failed.
There were no guidelines available on board or at the terminal to provide any assistance in the emergency methods for closing the valve. The valve was eventually blanked off with the tank pressure reduced to 0.02 bar gauge, but by this time a large amount of the product had been lost into the atmosphere. The investigation that followed discovered that there was a failure of the pilot valve diaphragm, possibly due to the diaphragms being in service for too long.
Additional info:The book advises on PRV maintenance and testing, emergency closure, and operating problems and faults. It is a general guide for the ship’s staff and is not designed to replace the manufacturers’ instruction manuals.
The purpose of SIGTTO is to promote shipping and terminal operations for liquefied gases which are safe, environmentally responsible and reliable. To fulfil this mission it will:
-Proactively develop best operating practices and guideline
-Sustain a learning environment by sharing lessons learned
-Promote training and development of all within the industry
-Foster mutually beneficial relationships with regulatory authorities and other stakeholders
-Conduct its business with professionalism and integrity
SIGTTO An Introduction to TheDesign and Maintenance Of Cargo System Pressure Relief Valves On Board Gas Carriers [2nd Edition 2014]
gillnumil ®   04-Sep-2019 18:33
New torrent file added.
Last post was 2nd Edition printed in 1998.
Edition remains the same in this file, being a Reprint 2014.
Content is same and so is number of pages. Changes in text layout and minor corrections.
Download only if you like keeping the latest. Otherwise its the same as last one.
LNG Operations in Port Areas - Essential Best Practices for the Industry - SIGTTO [2003, PDF]
Liquefied Gas Fire Hazard Management - SIGTTO [2004, PDF]
Jetty Maintenance and Inspection Guide - SIGTTO / OCIMF [2008, PDF]
Recommendations for Relief Valves on Gas Carriers - SIGTTO [2020, PDF]
Liquefied Gas Carriers: Your Personal Safety Guide - SIGTTO [2002, PDF]
Ship Vetting and its Application to LNG - SIGTTO [2004, PDF]
Recommendations For Relief Valves On Gas Carriers - SIGTTO [2020, PDF]
Liquefied Gas Cargo Resource Management Course - SIGTTO [2022, PDF]
The time now is: Today 15:57
