vitbar192 ®   03-Jul-2020 08:33
Marine applications of advanced fibre-reinforced composites
Year: 2016
Author: Graham-Jones J., Summerscales J.
Genre: Technical book
Publisher: Woodhead Publishing; Elsevier Ltd
ISBN: 0081002009
Pages count: 361
Description: The marine environment presents significant challenges for materials due to the potential for corrosion by salt water, extreme pressures when deeply submerged and high stresses arising from variable weather. Well-designed fibre-reinforced composites can perform effectively in the marine environment and are lightweight alternatives to metal components and more durable than wood. Marine Applications of Advanced Fibre-Reinforced Composites examines the technology, application and environmental considerations in choosing a fibre-reinforced composite system for use in marine structures.
This book is divided into two parts. The chapters in Part One explore the manufacture, mechanical behavior and structural performance of marine composites, and also look at the testing of these composites and end of life environmental considerations. The chapters in Part Two then investigate the applications of marine composites, specifically for renewable energy devices, offshore oil and gas applications, rigging and sails. Underwater repair of marine composites is also reviewed.
Comprehensively examines all aspects of fibre-reinforced marine composites, including the latest advances in design, manufacturing methods and performance
Assesses the environmental impacts of using fibre-reinforced composites in marine environments, including end of life considerations
Reviews advanced fibre-reinforced composites for renewable energy devices, rigging, sail textiles, sail shape optimisation and offshore oil and gas applications
Graham-Jones J., Summerscales J. Marine applications of advanced fibre-reinforced composites, 2016.pdf
Download [15 KB]
Maritime Composites - Richard Pemberton [2019, PDF]
Marine composites - design and performance - Graham-Jones J., Summerscales J. [2019, PDF/EPUB]
Durability Of Composites In A Marine Environment - Summerscales J. at all [2014, PDF]
Durability of Composites in a Marine Environment 2 - Davies P., Rajapakse Y.D.S. [2018, PDF]
Water-Lubricated Journal Bearings | Marine Applications, Design, and Operational Problems and Soluti...
Hydroblasting and Coating of Steel Structures - Andreas Momber [2003, PDF]
Corrosion and Protection of Marine Engineering Materials - Yanhua LEI (Edit [2023, PDF]
Valves, Piping and Pipelines Handbook - T.Dickenson [1999, PDF]
Design of Marine Risers with Functionally Graded Materials - SRINIVASAN CHANDRASEKARAN [2021, PDF]
Advanced welding processes: Technologies and process control - John Norrish [2006, PDF]
The time now is: Today 18:04
