twicer ®   06-Dec-2021 20:04
Ballast Water Management
Year: 202x
Author: North P&I Club
Pages count: 28
Description: The IMO Ballast Water Management (BWM) Convention entered into force in 2017 but at that time it applied only to new vessels. But a new milestone is now upon us – the Convention will apply to existing vessels from 8 September 2019.
From this date, existing vessels have up until its next IOPP Certificate renewal survey to comply. This effectively means that vessels whose keel were laid before 8 September 2017 are likely to need to install an approved ballast water treatment system (BWTS) at some point between 8 September 2019 and 8 September 2024, depending the date of IOPP certificate renewal.
New vessels have been complying with the ballast water regulations for the last two years with little fuss. There is a big difference, however, between installing a BWTS during newbuild and retrofitting a system on an existing vessel. On an existing vessel, such a system would not have been considered at time of original build and no dedicated space would have been allocated.
guidance on complying with ballast water regulations:
• Part 1 looks at the regulatory landscape.
• Part 2 considers the different treatment systems available.
• Part 3 focuses on the potential operational and commercial impacts.
Ballast-Water-Management_North.pdf
Ballast Water Management Advisory - ABS [2019, PDF]
Ballast Water Management (BWMP) + Working templates - DNVGL [2017, PDF / WORD]
Ballast Water Management FAQ - UK MCA [2020, PDF]
Guide for Ballast Water Treatment - ABS [2022, PDF]
Techcross BWTS-Ballast Water Treatment System [2013, AVI]
Guide for Ballast Water Treatment - ABS [2019, PDF]
Master’s Guide for Water Ingress Monitoring - SIMCO [20xx, PDF]
Ballast Water Management (11th Edition) - Witherby [2020, PDF]
Ballast Water Management for Yachts - ABS [201x, PDF]
The time now is: Today 13:53
