rochmanx12 ®   02-Jul-2021 18:05
Ballast Water Management 11th Edition
Year: 2020
Author: Witherby
Pages count: 467
Description: The Ballast Water Management Convention entered into force on 8th September 2017 and is now fully in effect for all applicable ships. This comprehensive guide provides up-to-date information on the regulations and equipment options available, and will assist shipowners with transition to full compliance. Of key significance in this edition is the deadline of 28th October 2020, after which point only BWMS holding a revised 2016 G8/BWMS Code Type Approval certificate are permitted to be installed. A new set of data sheets summarises the BWMS that meet this new requirement and facilitates easy comparison and evaluation of the various systems.
The book discusses the methods and considerations for safe ballast water exchange. It also provides detailed information on the various treatment technologies, including physical separation; thermal, ultraviolet and plasma technologies; and deoxygenation, magnetic and ultrasonic/cavitation technologies.
The book sets out the onboard requirements relating to ballast water management, including the Ballast Water Record Book, Port State Control, and ballast water sampling and monitoring.
The Appendices identify key invasive species and contain updated charts illustrating current native and invasive ranges, and areas potentially at risk.
Ballast Water Management Advisory - ABS [2019, PDF]
Technical Manual for BWMS AQ-0300-UV - Wartsila Water Systems Ltd [2016, PDF]
Guide for Ballast Water Treatment - ABS [2019, PDF]
Code For Approval Of Ballast Water Management Systems (BWMS CODE) - IMO [2018, PDF]
LR Ballast Water Management Plan Template D2 Standard 2025 - LR [2025, DOCx]
Guide for Ballast Water Treatment - ABS [2022, PDF]
Guide for Ballast Water Exchange - ABS [2018, PDF]
Ballast Water Management (BWMP) + Working templates - DNVGL [2017, PDF / WORD]
BWM - Guidance for best practices on sampling - EMSA [2019, PDF]
  • Topic closed
The time now is: Today 16:01
