CaptainWhite ®   18-Oct-2017 12:28
Ballast Water Management (BWMP) + Working templates
Year: 2017
Author: DNVGL
Publisher: DNVGL
Format: PDF / WORD
Pages count: 20
Description: Insights into the regulatory status, applicable treatment technologies and compliance solution
The BWM Convention was rati ed by a suf cient number of states on 8 September 2016, bringing the total gross tonnage to over 35% from the signatory states. This means the convention will enter into force 12 months later, on 8 September 2017. This implies that most vessels, which do not already have a ballast water treatment system installed, will be requested to install such equipment in the period 2017–2021 – in each case before the expiry date of the vessel’s IOPP certi cate.
Release including DNVGL booklet and 2 working BWMP templates
BWMP_DNVGL
Ballast Water Management Advisory - ABS [2019, PDF]
Ballast Water Management Plan [template] - ABS [202x, PDF]
Ballast Water Management - North P&I Club [202x, PDF]
Model Ballast Water Management Plan - Lloyd’s Register [2020, docx]
Guide for Ballast Water Treatment - ABS [2019, PDF]
Ballast Water Management (11th Edition) - Witherby [2020, PDF]
Ballast Water Contingency Measures for Tankers - Intertanko [2018, PDF]
Ballast Water Management: Ballast Water Management Plans & Ballast Water Record Books - Lloyd’s Regi...
Guidelines for Application of Ballast Water Treatment Systems on Ships - Machinery Team, Korean Regi...
The time now is: Today 05:39
