akil172 ®   10-Aug-2019 17:14
IACS Bulk Carrier -Guidelines for Survey, Assessment and Repair of Hull Structures
Year: 2017
Author: IACS
Genre: Technical book
Publisher: Witherby
Edition: 2
Pages count: 192
Description: These guidelines focus on IACS Member Societies' survey preparation guidelines. This book shows examples of structural deterioration and damage related to each structural area, demonstrating what to be aware of as well as possible causes and repair methods. The book will also be of use for the inspection/examination schemes of other regulatory bodies, owners and operators. This book provides guidelines for a bulk carrier type ship which is constructed with a single deck, single skin, double bottom, hopper side tanks and topside tanks in cargo spaces, and is intended primarily to carry dry cargo, including ore, in bulk.
Additional info: Print Quality is not up to the mark but readable.
Bulk Carrier -Guidelines for Survey, Assessment and Repair of Hull Structures.pdf
IACS Bulk Carriers Guidelines for Surveys, Assessment and Repair of Hull Structure - IACS [2007, PDF...
General Dry Cargo ships - Guide for surveys, assesment and repair of hull structures - IACS [2016, P...
Double Hull Oil Tankers - Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2...
Bulk Carriers – Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2007, PDF]
General Dry Cargo Ships – Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2...
Double Hull Oil Tankers - Guidelines for Surveys, Assessment and Repair of Hull Structures - Interna...
Double Hull Oil Tankers - Guide for Survey, Assessment and Repair of Hull Structures - IACS [2007, P...
Bulk Carriers: Guidelines for Surveys Assessment and Repair of Hull Structure - CCS [2014, PDF]
CONTAINER SHIPS. Guidelines for Surveys, Assessment and Repair of Hull Structures - The Internationa...
Guidance Manual for Tanker Structures, 2018 Consolidated Edition - Tanker Stracture Co-operative For...
The time now is: Today 07:20
