twicer ®   02-Nov-2021 11:43
Guide for Ice Loads Monitoring Systems
Year: 2021
Author: ABS
Pages count: 21
Description: This Guide provides requirements for the installation of, and the information to be provided by, Ice Loads
Monitoring Systems fitted on ice-classed vessels. These systems are intended as an aid to the Master
and navigating officers when a vessel is operating in ice infested waters
so that appropriate action can be
taken to minimize the likelihood of the vessel sustaining structural damage from interaction with the ice.
The Ice Loads Monitoring Systems specified by this Guide extend from basic monitoring systems to
sophisticated, integrated systems, the selection of which is left to the Owner. The information provided in
the Guide is intended to assist the Owner in selecting the most appropriate system for a vessel based on the
vessel’s probable operating parameters.
The Guide describes the Ice Loads Monitoring process and the procedures for collecting, recording,
processing, evaluating, and presenting the data in a manner that permits the Master and or navigating
officer to better measure vessel performance in ice
and determine if remedial action should be taken. The
monitoring systems specified in the Guide can assist in identifying when the vessel is operating in ice in a
manner that could lead to structural damage or failure by providing early warning to the navigator when
the performance parameters relating to vessel strength are approaching the preset allowable levels.
Release Date: September, 2021
Guide for Ice Loads Monitoring Systems ABS 2021.pdf
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
Ice Navigator Accreditation Standard for the Ice Navigator Training and Certification Scheme,…
ABS Guide for Vessel Maneuverability (Updated Feb 2017) - American Bureau of Shipping (ABS) [2006,…
Guide for Vessels Operating In Low Temperature Environments - ABS [2021, PDF]
NYK Standard for Navigation Using ECDIS - NYK Line [2014, PDF]
Guidelines on Ammonia Fueled Vessels - Indian Register of Shipping [2022, PDF]
Bulk Carriers - Guide & Info on Bulk Cargo Loading to Reduce the Likelihood of Over-stress the Hull…
Estimating The Environmental Loads On Anchoring Systems - OCIMF [2010, PDF]
The time now is: Today 19:31
