gillnumil ®   26-Oct-2021 10:34
Ultimate Strength of Ship Plating - A Proof of Capacity under Combined In-Plane-Loads
Year: 2016
Author: Richard C. Hayward
Publisher: Technische Universität Hamburg
ISBN: 978- 3-89220-699-6
Pages count: 261
Description: The present work addresses the need for a proof of plate capacity under combined in-plane loads, a need recently highlighted by the loss of the post-panamax container ship MOL Comfort.
Towards this end, an extensive series of numerical studies based on the finite element method have been performed covering all load combinations and plating configurations relevant for the shipbuilding industry. These studies have been used to investigate the mechanics of plating collapse (including the effects of plate slenderness and aspect ratio) under longitudinal, transverse and shear loads in isolation and in combination. Numerical studies have also been used to quantitatively evaluate existing proofs of plate capacity found in both literature and the shipbuilding industry.
Ultimate Strength of Ship Plating.pdf
The Principles of Naval Architecture Series--Strength of Ships and Ocean Structures - Prof. Alaa…
Advanced marine structures-CRC Press (2016) - Srinivasan Chandrasekaran [2016, PDF]
The Residual Strength of A Ship After an Internal Explosion - Stephen William Surko [1988, PDF]
On Structural Design of High-Speed Craft - Razolf M. [2013, PDF]
Design of Ship Hull Structures (A Practical Guide for Engineers) - Masaki Mano [2008, PDF]
Collection of COMPIT [2000 - 2014] - Volker Bertram [2014, PDF]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2025, PDF]
Analysis and Design of Marine Structures - C. Guedes Soares, J. Romanoff [2013, PDF]
Rules for the Classification and Construction of Sea-Going Ships - Russian Maritime Register of…
Probability and Mechanics of Ship Collision and Grounding - Shengming Zhang , Preben Terndrup…
The time now is: Today 13:29
