vitbar192 ®   22-Jun-2021 09:43
On Structural Design of High-Speed Craft
Year: 2013
Author: Razolf M.
Genre: Technical book
Publisher: KTH Royal Institute of Technology
ISBN: 978-91-7501-650-4
Pages count: 44
Description: The development in structural design and construction of high-speed craft has been extensive during the last decades. Environmental and economical issues have increased the need to develop more optimized structures, using new material concepts, to reduce weight and increase performance efficiency. However, both lack of, and limitations in design methodology, makes this a difficult task.
In this thesis a methodological framework which enables detailed studies of the slamming loads and associated responses for high-speed planing craft in irregular waves is established. The slamming loads can either be formulated based on numerical simulations, or on experimental measurements and pressure distribution reconstruction. Structure responses are derived in the time-domain using finite element analysis. Statistical methods are used to determine design loads and lifetime extreme responses.
The framework is applied to perform phenomenological studies of the slamming loading conditions for high-speed craft, and used to highlight and quantify the limitations in the prevailing semi-empirical method for design load determination with respect to slamming. A number of clarifications regarding the original derivation and the applicability of the prevailing semi-empirical method are presented. Finally, several potential improvements to the method are presented and the associated implications discussed.
Razolf M. Design of High-Speed Craft, 2013.pdf
Download [14 KB]
Engineering strategies for designing lightweight ship windows - Janne Heiskari [2024, PDF]
Air Lubricated and Air Cavity Ships: Development, Design, and Application - Pavlov G.A., Liang Y.,…
Determination of structural capacity by non-linear finite element analysis methods DNVGL-RP-C208 -…
Practical Design of Ships and Other Floating Structures - Volume 1 - You-Sheng Wu, Guo-Jun Zhou,…
Design of a free-rotating wing sail for an autonomous sailboat - Tretow C. [2017, PDF]
Dynamic Analysis and Design of Offshore Structures - Srinivasan Chandrasekaran [2015, PDF]
Advanced Marine Structures - Srinivasan Chandrasekaran [2016, PDF]
The Principles of Naval Architecture Series--Strength of Ships and Ocean Structures - Prof. Alaa…
The time now is: Today 15:04
