chayan_09 ®   19-Dec-2018 09:46
The Residual Strength of A Ship After an Internal Explosion
Year: 1988
Author: Stephen William Surko
Genre: Technical book
Publisher: MIT
Pages count: 250
Description: An internal airblast from a missile explosion produces tearing, holing, and dishing of a ships' structural plating. In order to analyze the residual strength of a ship after an internal explosion, a typical ship compartment was considered to be composed of flat square plates subjected to uniaxial compression, and the damage effects were examined independently. The holing was considered to be a centrally located circle. Plastic limit load analysis of a flat plate indicates that ultimate strength decreases in proportion to increasing hole size. Elastic-plastic analysis indicates that ultimate strength is little affected by hole size until the holing reaches half the plate width, and is essentially equal to the ultimate load described by the effective width concept. An extension of the concept of small imperfections to dished plates suggests that the ultimate strength is reduced by roughly 10 percent from that of a flat plate. The extensional collapse mode analysis describes folding and strength beyond peak load. Fully plastic crack propagation was examined, but its limiting effect can not be precisely described.
The Residual Strength of A Ship After an Internal Explosion - Stephen William Surko.pdf
Download [9 KB]
Damaged Ship III-International Conference Papers - RINA [2015, PDF]
Ultimate Strength of Ship Plating - A Proof of Capacity under Combined In-Plane-Loads - Richard C. H...
Advances in Marine Structures - Carlos Guedes Soares, Wolfgang Fricke [2011, PDF]
Mechanics of Materials - James M. Gere & Barry J. Goodno [2009, PDF]
Ship Collision Damage - Marie Lutzen [2001, PDF]
Fatigue assessment of stern ramps - ARON JALKEVIK AND KARL TORESSON [2013, PDF]
Buckling - DNV [2021, PDF]
Determination of structural capacity by non-linear finite element analysis methods DNVGL-RP-C208 - D...
Analysis and Design of Developable Surfaces for Shipbuilding - Julie Steele Chalfant [1997, PDF]
The time now is: Today 03:46
