twicer ®   27-Dec-2025 19:38
Guidelines for Direct Load Analysis and Strength Assessment
Year: 2025
Author: ClassNK
Publisher: ClassNK
Edition: 4.1 (December 2025)
Pages count: 33
Description: Ships need to be capable of ensuring and maintaining their structural functions whenever
they are in service, and today’s ships are more diversified and larger than ever before. This
means that ClassNK is always in search of new technical knowledge, either from recent
research or from organisations such as IACS (the International Association of Classification
Societies), to incorporate into its technical rules. Our goal is to constantly being reviewing our
requirements related to structural strength assessment so as to develop safer and more rational
requirements that continuously ensure ship structural integrity, even under the harshest sea
and weather conditions.
One of the structural strength assessment methods that require advanced technology is called
“Direct Load and Structural Analysis” and it employs direct load analysis and finite element
analysis. This method directly simulates the wave-induced loads acting upon ships and uses
structural strength assessments carried out by finite element analysis to reproduce these loads.
This method makes it possible to reproduce actual ship states to a high degree of accuracy and
thus evaluate the details of each ship characteristic correctly.
In order to make further use of direct load structural analysis, ClassNK publishes benchmark
test data as the base data of the analysis program, and at the same time, issues the fourth
edition of this Guidelines which specifies the requirements related to the benchmark data.
Direct Load Analysis_202512.pdf
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2023, PDF]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2022, PDF]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2024, PDF]
Wave loads - DNV GL [2018, PDF]
Advances in Marine Structures - Carlos Guedes Soares, Wolfgang Fricke [2011, PDF]
Guidance Notes on Fire-Fighting Systems - ABS [2017, PDF]
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS [2025, PDF]
Mooring Load Analysis during Ship to Ship Transfer Operations - OCIMF [2022, PDF]
The time now is: Today 15:18
