virtual ®   15-Jul-2018 04:41
Code For Approval Of Ballast Water Management Systems (BWMS CODE)
Year: 2018
Author: IMO
Genre: Convention (rules)
Pages count: 47
Description: The Code for Approval of Ballast Water Management Systems (BWMS Code) is aimed primarily at Administrations, or their designated bodies, in order to assess whether ballast water management systems (BWMS) meet the standard set out in regulation D-2 of the International Convention for the Control and Management of Ships' Ballast Water and Sediments, 2004 (the Convention). In addition, the Code is intended for manufacturers and shipowners as a reference on the evaluation procedure that equipment will undergo and the requirements placed on BWMS. The Code should be applied in an objective, consistent and transparent way and its application should be evaluated periodically by the Organization.
Amendments to BWMS Code and BWM Convention by
RESOLUTION MEPC.296(72)
(adopted on 13 April 2018)
RESOLUTION MEPC.297(72)
RESOLUTION MEPC.298(72)
(adopted on 13 April 2018) and
RESOLUTION MEPC.299(72)
were combined with Code to 1 pdf File of 47 Pages
Resolution MEPC.300(72) (adopted on 13 April 2018) Code For Approval Of Ballast Water Management Systems (BWMS CODE)
Plus the Amendments to BWMS Code and BWM Convention adopted by
RESOLUTION MEPC.296(72) (adopted on 13 April 2018)
RESOLUTION MEPC.297(72) (adopted on 13 April 2018)
RESOLUTION MEPC.298(72) (adopted on 13 April 2018) and
RESOLUTION MEPC.299(72) (adopted on 13 April 2018)
Ballast Water Management Convention and BWMS Code with guidelines for implementation - IMO [2018, PD...
Ballast Water Management Plan DNV template - DNV [2017, PDF]
Crude Oil Washing Systems - IMO [2000, PDF]
Ballast Water Management Plan [model] - Lloyd’s Register and IMO [2023, DOC/PDF]
Manual On Ballast Water Management – How To Do It - IMO [2017, PDF]
MARPOL Annex VI & NTC 2008 with Guides for Implementations - IMO [2017, PDF]
Rules for Construction and Equipment of Ships Carrying Dangerous Liquid Chemicals in Bulk, 2016 - CC...
Rules for Construction and Equipment of Ships Carrying Liquefied Gases in Bulk 2018 - CCS [2018, PDF...
Ballast Water Management (11th Edition) - Witherby [2020, PDF]
  • Topic closed
The time now is: Today 03:31
