Ferreirolo ®   04-May-2021 19:42
Guidance for Anchoring Equipment in Service
Year: 2014
Author: IACS
Publisher: IACS
Pages count: 10
Description: This document gives guidelines for maximum wear down of anchor cable fittings, joining shackles, the looseness of studs within anchor cable and the securing by welding of studs found loose during survey of chain cables links in service.
Anchor Cable Fittings
Anchor Pin Weardown
The Looseness of Studs in Anchor Chain Cable
The Securing by Welding of Chain Cable Studs in Service
Welding Procedure Specification
Welding Procedure Approval Tests
Repair Procedure
Examination
ANNEX
rec_79_pdf219.pdf
Download [349 B]
China ship building quality standard [2005, PDF]
Marine Chain Cable Pocket Guide - Lloyd’s Register [2011, PDF]
The Pocket Book of Anchoring - Captain Michael Lloyd [2009, PDF]
Noble Denton marine services - certification for towing vessel approvability - DNV GL [2017, PDF]
Guidelines on Technical Supervision of Ships in Service with Annexes - RMRS [2020, PDF]
Coating Maintenance– Guidelines for Coating Maintenance & Repairs for Ballast Tanks and Combined Car...
Guidance of Welders Qualification Tests - ClassNK [2022, PDF]
Effective Mooring [PDF]
Requirements concerning Gas Tankers - IACS [2018, PDF]
General Dry Cargo Ships – Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2...
The time now is: Today 23:31
