Astart ®   25-Dec-2013 19:41
Effective Mooring
Number of pages: 49
Description:
Chapter 1 Effective Mooring
Chapter 2 Mooring Winches
Chapter 3 Steel Wire Ropes
Chapter 4 Synthetic Fibre Ropes
Chapter 5 Mooring at Buoys
Chapter 6 Windlasses and Anchoring
Chapter 7 Personal Safety
What Does a Mooring System Do?
How Big Are These Forces?
Mooring Layout
Wires or Synthetic Fibre Ropes
Elasticity
First Line Ashore
Vertical Angle (Dip)
Mixed Mooring
Nylon Tails
Render and Heave
Winch Brakes
Correct Layering
Non Split Drum Winches
Split Drum Winches
Correct Reeling
Brake Condition
Testing Brakes
Application of Brake
Incorrect Use of Brake
Brake Holding Capacity
Exceptional Circumstances
Winch In Gear
Freezing Weather
Joining a New Ship
Safety Reminders
Construction of Wire Ropes
Maintenance of Steel Wire Moorings
Selection of Anchor Point for 1st Layer of Wire on a Drum
Stoppers for use with Steel Wires
Care of Wire
Splicing Wire
Safety Reminders
Use of Synthetic Fibre Ropes
Types of Materials Used
Rope Care
Rope Stoppers
Splicing
Snapback
Safety Reminders
Conventional or Multibuoy Moorings (CBM or MBM)
Single Buoy Moorings (SBM)
Brakes
Cable Stoppers
Anchor Cables
Communication
Maintenance of Windlass Brakes
Adjustments
Prolonged Periods of Non-Use
Safety Reminders
Handling of Moorings
Safe Handling of Tug Lines
Cloves
Safety Reminders
Effective Mooring.pdf
Download [7 KB]
Guest   22-Dec-2015 12:27
Do mrg wires on board need to be be replaced after 5 yrs of service ? where does it say so
Arcan   20-Nov-2016 19:36
26775Hi. Torrent file damaged.
Regards
Step
Torrent isn't damaged. Just tested. You need proper software to open this file. For example Adobe Reader
step71   23-Nov-2016 08:57
Good morning Arcan. When I said the torrent is damaged means I cannot open the torrent file to download the pdf document. I am using thè same sofware I use for all other files. I had problem to load the torrent on bittorrent. That is the reason why you have changed my reputation? Since I discover this site, more than 2 years ago, it becomes very important for my job and honestly I see no reason why a reputation should be affected for such non relevant issue. I kindly ask you to remove the negative feedback as apparently I am not anymore allowed to download any file.. hope you understand. Thank you. Have a nice day, stefano
Arcan   23-Nov-2016 19:05
26794Good morning Arcan. When I said the torrent is damaged means I cannot open the torrent file to download the pdf document. I am using thè same sofware I use for all other files. I had problem to load the torrent on bittorrent.
Check first your bittorrent client. Torrent is not damaged and easily loaded to my bittorrent clients. Problem with your client.
step71   24-Nov-2016 06:55
Good day Admin, Arcan. It worked. It was a browser issue. Many thanks! Any chance to have the reputation recovered? I believe such issue shouldn't compromize the user reputation. Hope you understand..
Have a nice day
Mooring Equipment Guidelines (MEG4) - Oil Companies International Marine Forum (OCIMF) [2018, PDF]
Tugs and Tows - A Practical Safety and Operational Guide - Chris Spencer [2014, PDF]
Lessons Learned: What is render testing? - RightShip [2020, PDF]
SAMSON Rope Catalogue - SamsonRope [2011, PDF]
Hearst Marine Books Complete Guide to Anchoring and Line Handling - David G. Brown [1996, PDF]
Samson Technical Bulletin - Samson rope Inc [2018, PDF]
The Hazards of Snap-back: Initial learnings from a serious incident of mooring line failure - Oil Co...
Handbook of Oceanographic Winch, Wire, and Cable Technology - J.Bash [2001, PDF]
Anchoring systems and Procedures - OCIMF [2010, PDF]
Recommendation on Onboard Lifting Appliances (Rec.198) - IACS [2026, PDF]
The time now is: Today 23:45
