gillnumil ®   15-Sep-2019 14:39
Hydroblasting and Coating of Steel Structures
Year: 2003
Author: Andreas Momber
Publisher: Elsevier Advanced Technology
Edition: 1st
ISBN: 185617395X
Pages count: 222
Description: A practical and comprehensive account of the technology and applications of hydroblasting, a technique used more and more in the preparation of steel and other surfaces. Steel surfaces will corrode unless they are properly prepared and coated. Such corrosion can have disastrous effects therefore the preparation of the surface is of major importance. Due to environmental pressure to move away from grit-blasting, high-pressure water can now be used to prepare surfaces, with few environmental costs. This book systematically and critically reviews the state of current hydroblasting technology and its applications. The book is essentially practical in nature and is written by an expert in the field.
Hydroblasting_and_Coating_of_Steel_Structures.pdf
Download [7 KB]
Corrosion Control for Offshore Structures: Cathodic Protection and High-Efficiency Coating - Ramesh…
High Pressure Pumps - Gracey M.T. [2006, PDF]
Marine applications of advanced fibre-reinforced composites - Graham-Jones J., Summerscales J.…
Protective Coating Corrosion Control [2024, MP4]
Production Chemicals for the Oil and Gas Industry - Malcolm A. Kelland [2014, PDF]
LaQue’s Handbook of Marine Corrosion - David A. Shifler [2022, PDF]
Cathodic Protection Corrosion Control System [2024, MP4]
Shipbuilding (Gemi İmalatı) - Ahmet Tokgöz, Atilla Yurdagül [2020, PDF]
The time now is: Today 15:17
