sourabhharel96 ®   14-Apr-2021 10:25
Selecting Materials For Sea Water System
Year: 1999
Author: B. TODD,
Genre: Reference book
Publisher: IMarEST
ISBN: 0900976497
Pages count: 29*2
Description: Combating the effects of corrosion has been a feature of
seafaring life for centuries. Even 30 years ago a common
complaint was 'condenseritis' in steam ships but in time
new materials were tried and tested to cure this problem
and others of similar nature. It was often found that curing
one problem produced another and so improvements were
brought about gradually and piecemeal.
With the advent of large modern high-powered steam
ships it became economically justifiable to incorporate
more sophisticated materials in salt water circulating
systems in an effort to obtain increased reliability. Unfortunately
many of the problems which have subsequently
developed appear to be associated with errors in the
design of minor details and the methods of installing the
pipes, fittings, and components which comprise a 'system'.
Because of this the in-service reliability of two similar
systems may be very different. This booklet is intended to
explain how and why this can come about so that the
reader can recognize potential difficulties before they
become problems and to enable him to apply the correct
materials and methods to the repair of an existing problem.
MEP Vol. 1.10 Material Selection For SW Systems.pdf
Ships Gear: A Review of Deck Machinery - D. H. BEATTIE and W. M. SOMERVILLE [1978, PDF]
Steering Gear - W. S. PAULIN, [1981, PDF]
Operation of Machinery in Ships: Steam Turbine, Boilers and Auxiliary Plant - A. NORRIS, C.Eng., F.L...
Application Of Automatic Machinery and Alarm Equipment’s In Ships - B. G. SMITH [1979, PDF]
The Practical Mariners Book of Knowledge - John Vigor [2013, EPUB]
Boiler Water Treatment - J. D. SKELLY, B.Sc., Chart. Chemist, M.R.I.C. [1990, PDF]
Sea Water Corrosion of Stainless Steels - Mechanisms and Experiences - Working Parties on Marine Cor...
Production Chemicals for the Oil and Gas Industry - Malcolm A. Kelland [2014, PDF]
Hydroblasting and Coating of Steel Structures - Andreas Momber [2003, PDF]
High Voltage Engineering Practice and Theory - Dr JP Holtzhausen Dr WL Vosloo [2007, PDF]
The time now is: Today 16:48
