sourabhharel96 ®   14-Apr-2021 09:20
Application Of Automatic Machinery and Alarm Equipment's In Ships
Year: 1979
Author: B. G. SMITH
Genre: Reference book
Publisher: IMarEST
ISBN: 0 900976 15 2
Pages count: 47*2
Description: With the advent of steam propulsion machinery in ships, a very primitive form of instrumentation was also introduced. The pressure gauge, the basic principle of which has remained unchanged since it was first used, was one piece of equipment that the early marine engineers could ill afford to ignore. It soon became obvious that human error was inevitable, and to prevent the steam pressure from rising above the design limits, the automatic safety valve for boilers was introduced. This, in conjunction with the centrifugal governor for rotating machinery, was probably the first experience marine engineers had of the value which should be attached to automation equipment.
MEP Vol. 1.6 Automation And Alarm Equipment.pdf
Download [5 KB]
Hydraulic Power Transmission In Marine Machinery - C. M. JOY [1990, PDF]
Fire Fighting Equipment’s and its Use In Ships - G Victory [1981, PDF]
Welding for Beginners: Step wise guide for form welding to workshop projects - Unknown [2021, PDF]
Steering Gear - W. S. PAULIN, [1981, PDF]
Robust Control of Diesel Ship Propulsion - Nikolaos Xiros, Dr-Eng [2002, PDF]
Ships Gear: A Review of Deck Machinery - D. H. BEATTIE and W. M. SOMERVILLE [1978, PDF]
Marine Power Plant - Zongming Yang and Others [2021, PDF]
Marine Engineering Diploma [2023, MP4]
Notes on Instrumentation and Control (Marine Engineering Series) - G. J. Roy - G. J. Roy [1994, PDF]
Guidelines for the Prevention of Human Error Aboard Ships - ClassNK [201’, PDF]
The time now is: Today 23:48
