sourabhharel96 ®   14-Apr-2021 11:33
Operation of Machinery in Ships: Steam Turbine, Boilers and Auxiliary Plant
Year: 1978
Author: A. NORRIS, C.Eng., F.LMar.E.
Genre: Reference book
Publisher: IMarEST
ISBN: 0 900976 80 2
Pages count: 122
Description: This Part of Marine Engineering Practice Volume 2 deals with the operation
of steam turbine installations in ships, with particular reference to
systems rather than to the main turbine/gearing/boiler components which
are well covered in existing technical literature. The systems discussed are
those installed with a modern power plant of about 22000 kW installed in
a large tanker: comments are also relevant to similar plant in other types of
ship. Machinery installations are so varied-typically in number of boilers,
and closed feed and feed heating systems-that no attempt is made to
cover the variations in detail, since the general principles of operation are
the same and methods discussed can easily be amended to suit specific
cases. Restrictions on the length of the present text also precludes discussion
of maintenance procedures.
MEP Vol. 2.15 Steam Turbines, Boilers & Auxiliary Plant.pdf
Download [6 KB]
Operation of Machinery In Motorships: Main diesels, Boilers and Auxiliary Plant - A. NORRIS,…
Prime Movers for Generation of Electricity- (A) Steam Turbines - A. NORRIS, C.Eng., F.I.Mar.E.…
Ships Gear: A Review of Deck Machinery - D. H. BEATTIE and W. M. SOMERVILLE [1978, PDF]
Corrosion for Marine and Offshore Engineers - J. C. ROWLANDS, [1981, PDF]
Principles of Naval Engineering: Propulsion and Auxiliary Systems - Matthew A. Carr [2012, PDF]
Marine Steam Boilers - James H. Milton, Roy M. Leach [1980, PDF]
MEP. Marine Engineering Practice - Vol.1 Part.8 - Marine Steam Turbine - R.Coats, C.Eng [201x, PDF]
Marine Machinery - Liviu Constantin Stan (Nautica) [2010, PDF]
Modern Marine Engineer’s Manual Volume 2 - Everett C. Hunt [2002, EPUB/PDF/AZW]
Marine Power Plant - Zongming Yang and Others [2021, PDF]
The time now is: Today 15:20
