Ferreirolo ®   26-Nov-2020 20:20
DNV GL class documents
Year: 2020
Author: DNV GL
Genre: Convention (rules)
Publisher: DNV GL
Pages count: Over 10.000
Description: Rules for classification, class programmes, class guidelines, offshore standards and statutory interpretations
2020-09.
The electronic PDF versions of the documents, available at the DNV GL website dnvgl.com, are the official, binding versions. To search in all listed documents, press Ctrl+Shift+F, or select Menu>Edit>Advanced search.
547 files in pdf searchables
Table of contents
PART 7 FLEET IN SERVICE EDITION Ch.1 Survey requirements for fleet in service 2020-07
Ch.2 Retroactive requirements 2015-12
DNV GL rules for classification: Inland navigation vessels (RU-INV)
AMENDED NEW/REV. Rev.
AMENDED NEW/REV.
AMENDED NEW/REV.
AMENDED NEW/REV.
2017-07 AMENDED NEW/REV.
PART 6 ADDITIONAL CLASS NOTATIONS
Ch.1 Transport of dangerous goods Ch.2 Ship strength Ch.3 Cargo operations Ch.4 Ferry Ch.5 Stability Ch.6 Additional fire protection for passenger vessels
Ch.1 Survey requirements Ch.2 Inclining test and light weight check
DNV GL rules for classification: Yachts (RU-YACHT)
PART 1 GENERAL REGULATIONS
Ch.1 General regulations Ch.2 Class notations Ch.3 Documentation and certification requirements,
general 2015-12 2015-12 2015-12
EDITION AMENDED NEW/REV. 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12
EDITION AMENDED NEW/REV. 2016-01
2015-12
EDITION AMENDED NEW/REV. 2015-12 2017-07 2015-12 2018-01 2019-07
PART 2 MATERIALS AND WELDING EDITION AMENDED NEW/REV.
Ch.1 General requirements for materials and fabrication
Ch.2 Metallic materials
Ch.3 Non-metallic materials
Ch.4 Fabrication and testing
PART 3 HULL
Ch.1 Design principles Ch.2 General arrangement design Ch.3 Hull design loads Ch.4 Metallic hull girder strength and local scantlings Ch.5 Composite scantlings Ch.6 Finite element analysis Ch.7 Rudder, foundations and appendages Ch.8 Hull equipment Ch.9 Opening and closing appliances Ch.10 Stability
PART 4 SYSTEMS AND COMPONENTS
Ch.1 Machinery and systems, general Ch.2 Rotating machinery, general Ch.3 Rotating machinery - drivers Ch.4 Rotating machinery - power transmission Ch.5 Rotating machinery - driven units Ch.6 Piping systems Ch.7 Pressure equipment Ch.8 Electrical installations Ch.9 Control and monitoring systems Ch.10 Steering gear Ch.11 Fire safety
PART 5 SHIP TYPES
Ch.1 Sailing yachts 2015-12 2015-12 2015-12 2015-12
EDITION AMENDED NEW/REV. 2016-10 2016-10 2019-07 2016-10 2018-01 2018-01 2018-07 2016-10 2019-07 2019-07 2016-10 2016-10
EDITION AMENDED NEW/REV. 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2015-12 2016-10
Ch.2 Propulsion and manoeuvring equipment Ch.3 Ballasting, compensating and trimming systems Ch.4 Life support systems Ch.5 Umbilicals Ch.6 Piping systems, pumps and compressors Ch.7 Pressure vessels Ch.8 Electrical installations Ch.9 Control and monitoring systems Ch.10 Fire safety
PART 5 TYPES OF UWT SYSTEMS
Ch.1 Manned hyperbaric systems Ch.2 Saturation diving systems Ch.3 Surface oriented diving systems Ch.4 Diving simulators Ch.5 Self-contained diver pressure chamber systems Ch.6 Manned submersibles Ch.7 Remotely operated vehicles Ch.8 Autonomous underwater vehicles Ch.9 Underwater working machines and systems
PART 6 ADDITIONAL FEATURES
Ch.1 General
PART 7 SYSTEMS IN SERVICE
DNV GL rules for classification: Naval vessels (RU-NAVAL)
PART 1 CLASSIFICATION AND SURVEYS
Ch.1 Reasons for naval classification Ch.2 Scope, application Ch.3 Class notations Ch.4 Surveys for surface ships 2015-12 2015-12 2015-12 2018-01 2015-12 2015-12 2018-01 2018-01 2019-07 2015-12 2015-12
EDITION AMENDED NEW/REV. 2015-12 2015-12 2015-12 2015-12 2018-01 2018-01 2018-01 2018-01 2015-12 2018-01 2015-12
EDITION AMENDED NEW/REV. 2015-12 2015-12 2018-07 2016-01
AMENDED NEW/REV.
Rev. AMENDED NEW/REV.
AMENDED NEW/REV.
AMENDED NEW/REV.
Rev.
DNVGL-RU-OU-0103 Floating LNG/LPG production, storage and loading units
DNVGL-RU-OU-0104 Self-elevating units, including wind turbine installation units and liftboats
DNVGL-RU-OU-0294 Modular systems for drilling and well
DNVGL-RU-OU-0300 Fleet in service
DNVGL-RU-OU-0375 Diving systems
DNVGL-RU-OU-0503 Offshore fish farming units and installations
DNV GL class guidelines (CG)
DNV GL class programmes (CP)
0 GENERAL
DNVGL-CP-0068 Certification of container securing devices
DNVGL-CP-0337 General description of services for certification of materials and components
DNVGL-CP-0429 Corrosion resistant steels for cargo oil tanks
DNVGL-CP-0483 Mass and serial produced engines - Alternative product certification scheme
DNVGL-CP-0484 Approval of service supplier scheme
1 TYPE APPROVAL
DNVGL-CP-0031 Stern tube sealing arrangement
DNVGL-CP-0069 Welding consumables
DNVGL-CP-0070 Fibre reinforced thermosetting plastic piping systems - Non-metallic materials
DNVGL-CP-0072 Thermoplastic piping systems - Non-metallic materials
DNVGL-CP-0081 Synthetic bearing bushing materials
DNVGL-CP-0082 Glass fibre rovings
DNVGL-CP-0083 Polyester resin, vinylester resin, gelcoat and topcoat
DNVGL-CP-0084 Sandwich core materials
DNVGL-CP-0085 Sandwich adhesives - Non-metallic materials
DNVGL-CP-0086 Adhesive systems
DNVGL-CP-0089 Epoxy resin systems
DNVGL-CP-0092 Aramid fibre reinforcements - Non-metallic materials
DNVGL-CP-0093 Composite drive shafts and flexible couplings
DNVGL-CP-0094 Side scuttles and windows
DNVGL-CP-0095 Pourable compound for rope socketing
DNVGL-CP-0096 Carbon fibre tows
DNVGL-CP-0097 Core materials for use in sandwich plate system (SPS) or similar
DNVGL-CP-0098 Plywood
DNVGL-CP-0099 Hardwood for tank supports - Non-metallic materials
DNVGL-CP-0100 Synthetic fibre ropes for towing, mooring and anchoring
DNVGL-CP-0106 Fastening devices for sacrificial anodes - Metallic materials
DNVGL-CP-0107 Sacrificial anode materials - Metallic materials
DNVGL-CP-0108 Protective coating systems for seawater ballast tanks and double-side skin spaces
DNVGL-CP-0109 Shop primers for corrosion protection of steel plates and sections
DNVGL-CP-0110 Anti-fouling systems
DNVGL-CP-0139 Protective coating systems for cargo oil tanks -Non-metallic materials
DNVGL-CP-0140 Passenger and crew seats
DNVGL-CP-0144 Flexible mounts used for propulsion or auxiliary machinery
DNVGL-CP-0147 Elastic (torsional) couplings for torque transmission in propulsion or auxiliary plants
DNVGL-CP-0148 Couplings used for torque transmission in propulsion or auxiliary plants
DNVGL-CP-0149 Clutches used for torque transmission in propulsion or auxiliary plants
DNVGL-CP-0165 Cable and pipe penetrations
DNVGL-CP-0183 Flexible non-metallic hoses
DNVGL-CP-0184 Flexible hoses with permanently fitted couplings -Metallic materials
DNVGL-CP-0185 Mechanical joints
DNVGL-CP-0186 Valves
DNVGL-CP-0187 Air vent heads
DNVGL-CP-0191 Gear transmission used in propulsion or auxiliary plants
2016-03 2016-03 2015-12
2015-12 2016-04 2016-02 2016-02 2016-03 2016-02
2016-03 2015-12 2016-03 2015-12 2015-12 2017-04 2016-04 2016-03 2015-12 2016-03 2018-07 2016-03 2016-03 2016-03 2017-10 2018-01 2015-12 2016-03 2015-12 2016-03 2016-03
DNVGL-CP-0201 Steering gear control system DNVGL-CP-0203 Electronic and programmable equipment and
systems DNVGL-CP-0206 Machinery planned maintenance system (MPMS) DNVGL-CP-0208 5 ppm bilge water separators DNVGL-CP-0209 Ballast water management systems DNVGL-CP-0210 Fuel oil separators DNVGL-CP-0211 Tank washing machines DNVGL-CP-0212 Continuous drip fuel sampler DNVGL-CP-0213 Fire safety equipment DNVGL-CP-0231 Cyber security capabilities of systems and
components DNVGL-CP-0282 Spark arrestors DNVGL-CP-0291 Additive manufacturing feedstock DNVGL-CP-0293 Abrasion resistant coatings DNVGL-CP-0338 Type approval scheme DNVGL-CP-0353 Selective catalytic reduction system DNVGL-CP-0392 Busbar trunking systems DNVGL-CP-0393 Rotating electrical machines DNVGL-CP-0394 Transformers - power and measurement DNVGL-CP-0395 Semiconductor converters DNVGL-CP-0396 Low-voltage switchgear and controlgear - rated voltage does not exceed 1000V AC or 1500V DC DNVGL-CP-0397 Instruments for switchboard DNVGL-CP-0398 Luminaires DNVGL-CP-0399 Electric cables DNVGL-CP-0400 Lightweight electric cables DNVGL-CP-0401 Electric high voltage cables DNVGL-CP-0402 Optical fibre cables DNVGL-CP-0403 Data communication cables - category cables DNVGL-CP-0404 Maritime LAN - Horizontal cabling - Copper permanent link DNVGL-CP-0405 Fire protective systems for cables DNVGL-CP-0406 Heat shrinkable tubing
2016-03
2015-12 2016-10 2016-03 2016-03 2016-03 2016-03 2018-01 2016-03 2016-03 2016-03 2020-03
2016-03 2019-06 2018-07 2018-09 2016-05 2019-07 2015-12 2015-12 2015-12 2015-12
2015-12 2015-12 2016-03 2019-07 2016-02 2019-07 2019-07 2019-07
2016-03 2015-12
DNVGL-CP-0407 Cable ties DNVGL-CP-0408 Cable glands DNVGL-CP-0409 Terminal lugs for LV power cables with aluminum
conductors
DNVGL-CP-0413 Carbon and PBO cable rigging for sailing yachts
DNVGL-CP-0417 Flexible electric cables
DNVGL-CP-0418 Electrical energy storage
DNVGL-CP-0424 Coatings for protection of FRP structures with heavy rain erosion loads
DNVGL-CP-0428 Coating systems for protection of propeller shafts
-Non-metallic materials DNVGL-CP-0431 Prepreg materials - Non-metallic materials DNVGL-CP-0432 Pourable compounds for foundation chocking DNVGL-CP-0434 Uni- and multi-axial multi-ply fabrics made of carbon fibres DNVGL-CP-0467 Uni- and multi-axial multi-ply fabrics made of glass fibres DNVGL-CP-0485 5 ppm bilge alarms DNVGL-CP-0501 Booster units DNVGL-CP-0502 Oil spray protection systems DNVGL-CP-0505 Pumping units for liquids
DNVGL-CP-0509 Rigid couplings with special friction treatment DNVGL-CP-0553 Containerized systems
3 APPROVAL OF MANUFACTURERS
DNVGL-CP-0173 Offshore fibre ropes DNVGL-CP-0174 Synthetic fibres for designated service in ropes DNVGL-CP-0237 Offshore mooring chain and accessories DNVGL-CP-0242 Semi-finished steel products DNVGL-CP-0243 Rolled steel products - non-stainless steel DNVGL-CP-0244 Rolled austenitic and ferritic-austenitic stainless
steel products
DNVGL-CP-0245 Clad steel and steel-aluminium transition joints
DNVGL-CP-0246 Steel castings
DNVGL-CP-0247 Steel forgings
DNVGL-CP-0248 Wrought aluminium alloys
DNVGL-CP-0249 Iron castings 2016-02 2020-09 Rev. 2018-01
2016-11 2015-12 2020-07 Rev. 2016-05
2015-12
2015-12
2016-04
2015-12 2016-04
2015-12 2016-04
2016-03
2018-09
2018-09
2019-07
2019-12
2020-06 New
EDITION AMENDED NEW/REV. 2018-10 2018-10 2018-07 2016-05 2019-02 2016-05 2016-05 2016-05 2016-05 2016-05 2016-05 Legal disclaimer Copyright © DNV GL AS
DNVGL-Class
Download [36 KB]
Abyrax   26-Nov-2020 21:18
Спасибо, крутяк) полезная информация
4
Germanischer Lloyd Rules ND and Programms 14.0 [2012 Edition]
Rules of Russian Maritime Register of Shipping - RMRS [2018, PDF]
Rules of Korean Register of Shipping - KR [2018, PDF]
Guide For Materials and Welding for Stainless Steels, 2019 - ABS [2018, PDF]
Rules of Bureau Veritas (BV) - [2018, PDF]
IEC 60092 - Electrical Installations in Ships - IEC [2016, PDF]
Rules for the Classification and Construction of Sea-Going Ships - Russian Maritime Register of…
Construction Standards For Small Vessels - Her Majesty the Queen in Right of Canada [2004, PDF]
The time now is: Today 13:25
