vitbar192 ®   17-Jun-2021 10:18
Construction Standards For Small Vessels
Year: 2004
Author: Her Majesty the Queen in Right of Canada
Genre: Documentation
Publisher: Her Majesty the Queen in Right of Canada
Pages count: 145
Description: Construction Standards For Small Vessels
Table of Contents
Document Information
Referenced Organizations
Application of Sections
Introduction
0.1. Definitions
0.2. Pleasure Craft of more than 24 Metres
0.3. Standard Incorporated by References
0.4. Particular Vessel Design
0.5. Major Modifications
0.6. Plans
0.7. Safety Notices
1. Hull Serial Numbers
1.1. Scope
1.2. Hull Serial Number ( HIN )
2. Compliance Notices
2.1. Scope
2.2. Compliance Notices
3. Construction Requirements
3.1. Scope
3.2. Structural Strength
3.3. Watertight Integrity
3.4. Personal Watercraft
3.5. Protection from Falls
3.6. Discharge of Sewage
3.7. Navigation Lights
4. Hull Design Requirements and Calculation of Recommended Maximum Capacities for Vessels not more than 6 Metres in Length
4.1. Scope
4.2. Definitions
4.3. Recommended Maximum Safety Limits for Monohull Vessels
4.4. Flotation Requirements for Monohull Vessels
4.5. Recommended Maximum Safety Limits for Pontoon Vessels
4.6. Recommended Maximum Safety Limits for Inflatable and Rigid Hull Inflatable Vessels
5. Hull Design Requirements for Non-Pleasure Craft Exceeding 6 Metres
5.1. Scope
5.2. Stability Standards for all Types of Vessels
5.3. Stability Standard for Monohull Vessel other than Inflatable or Rigid Hull Inflatable
5.4. Stability Standard for Pontoon Vessels
6. Ventilation Systems
6.1. Scope
6.2. General
6.3. Ventilation of Spaces Containing Source of Gasoline Vapour
6.4. Diesel Engine and Fuel Tank Space Ventilation
6.5. Battery Spaces
7. Fuel Systems
7.1. Scope
7.2. General
7.3. Fuel Tanks
7.4. Fuel Lines
7.5. Fittings, Joints and Connections
7.6. Fuel Line Valves
7.7. Fuel Filters and Strainers
7.8. Fuel Pumps
7.9. Grounding
7.10. Carburetors (Gasoline)
7.11. Fuel System Labelling
7.12. Outboard Motor Installations
8. Electrical Systems
8.1. Scope
8.2. Alternative Standards
8.3. General
8.4. Ignition Protection
8.5. Grounding
8.6. Batteries
8.7. Conductors
8.8. Receptacles
8.9. Overcurrent Protection
8.10. Panelboards
8.11. Emergency Lighting for Non-Pleasure Craft of more than 6 Metres
8.12. Electrical Systems of 50 Volts or more
9. Machinery Systems
9.1. Exhaust Systems
9.2. Main and Auxiliary Machinery
9.3. Bilge Pumping Arrangements
9.4. Pressure Vessels
10. Fire Safety
10.1. Scope
10.2. Means of Escape
10.3. Fire Detection and Alarm
10.4. Fire Fighting
Appendices
Declaration of Conformity Forms and Process
1.1. Manufacturer Identification Code ( MIC )
1.2. Declaration of Conformity
1.3. Annual Production Report
1.4. Technical Documents, Test Reports and Calculations
1.5. Guidelines for the Technical Information
1.6. Conformity of Second-Hand or Rebuilt Vessels
Sewage Holding Tank Systems
2.1. General
2.2. System Types
2.3. Portable Toilets
2.4. Holding Tank Systems
Noise Reduction on Power-Driven Vessels
3.1. General
3.2. Guidance Notes Relating to Possible Engine Exhaust Noise Muffling Arrangements
Measuring and Calculation of Total Hull Volume for Monohull Vessels
4.1. Measuring of Monohull Vessels
4.2. Calculation of Total Hull Volume
4.3. Calculation Worksheet for Determining Total Hull Volume of Monohull Vessels
Compliance Notice Ordering Process and Forms
5.1. Compliance Notice Ordering Process
Construction Standards For Small Vessels, 2004.pdf
Download [1 KB]
Electrical Engineer’s Portable Handbook - Robert B. Hickey, P.E. [2004, PDF]
Boat mechanical systems handbook. How to design, install, and evaluate mechanical systems - Dave…
FPSO Handbook - Angus Mather [2009, PDF]
IEC 60092 - Electrical Installations in Ships - IEC [2016, PDF]
(BLCH) Guide , Bulk Liquid Chemical Handling Guide for Plants, Terminals, Storage and Distribution…
Bunkering [2017, MP4]
Safety Recommendations for Decked Fishing Vessels of Less than 12 metres in Length and Undecked…
International Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk…
Life-Saving Appliances Including LSA CODE Spanish Version - IMO [2017, PDF]
The time now is: Today 17:46
