Year: 2012 Version: ver. 2,800,0 Edition 2012 Platform: PC Compatibility with Windows7: yes Localization: english Crack: Not needed Description:GL Rules and Programs (GLRP), Version 14.0/2012 is an interactive Microsoft Windows-based information and calculation system thatngives you easy access to GL Rules and Guidelines. GLRP allows you to search and view rule information relevant tobyour needs. The rules are displayed with the Acrobat Reader from Adobe**). In addition you can calculate scantling requirements for the hull structures of various ship types using the program GL Rules ND. **) Adobe Systems Incorporated. All rights reserved. Adobe and Acrobat are Trademarks of Adobe Systems Incorporated.3 Системные требования / System Requirements: * PC running Windows XP or higher * About 400 MB free hard disk space for the complete local installation * Acrobat Reader 4.0 or higher Setting Up GL Rules and Programs Start your Windows system and insert the GL Rules and Programs CD into your CD-ROM drive. Use the appropriate setup program from the AcroRead directory (SETUP.EXE) to install the Acrobat Reader, if the reader isn’t installed yet. After you have successfully installed the Acrobat Reader, use the setup program (SETUP.EXE) to install GL Rules and Programs on your computer. Install GL Rules and Programs * From the Start Menu choose run. * Type the drive letter of your CD-ROM drive followed by a colon and SETUP.EXE. * Follow the self-explanatory instructions of the setup program. Choosebthe CD-ROM/Server Installation which is the default selection. Only thebprogram icons will be installed on your computer. If you choose the local installations, you can copy all books and programs to a local drive. 14 Viewing GL Rules and Guidelines Ensure that GLRP has been installed successfully as described in the previous section. Double-click the Rules and Guidelines (deutsch) icon for the German version or the Rules and Guidelines (english) icon for the English version to enter structure and contents of the GL Rules and Guidelines. Tips and Tricks Inside the main contents file of Rules & Guidelines is a link to the newest version of the document Tips and Tricks. Follow this link and read the latest news for using Rules & Guidelines with the Acrobat Reader. Calculating with GL Programs All programs, which are available on the CD-ROM can be started by double-clicking the appropriate icon. The setup program of GL Rules and Programs installs the icons in the program group “Germanischer Lloyd Rules and Programs 14.0/2012”.15 Programmed Rules GL Rules ND The program contains computation modules for the following GL Rules I Ship Technology Part 1 Seagoing Ships Chapter 1 Hull Structures Chapter 5 Structural Rules for Container Ships Part 2 Inland Navigation Vessels Chapter 2 Hull Design and Construction Part 3 Special Craft Chapter 1 High Speed Craft Chapter 2 Yachts ≥ 24m Chapter 3 Yachts and Boats up to 24m Part 6 Offshore Service Vessels Chapter 1 Hull StructuresReproduction, use and transfer restricted.
GL Rules and Guidelines 4 I Ship Technology 4 II Materials and Welding 6 III Naval Ship Technology 7 IV Industrial Services 8 V Analysis Techniques 8 VI Additional Rules and Guidelines 9 IACS Common Structural Rules 12 System Requirements 13 Setting Up GL Rules and Programs 13 Viewing GL Rules and Guidelines 14 Tips and Tricks 14 Calculating with GL Programs 14 Programmed Rules 154 GL Rules and Guidelines I Ship Technology Part 0 Classification and Surveys Part 1 Seagoing Ships Chapter 1 Hull Structures Chapter 2 Machinery Installations Chapter 3 Electrical Installations Chapter 4 Automation Chapter 5 Structural Rules for Container Ships Chapter 6 Liquefied Gas Carriers Chapter 7 Chemical Tankers Chapter 8 Fishing Vessels Chapter 9 Oil Recovery Vessels Chapter 10 Refrigerating Installations Chapter 11 One-Man Control Console Chapter 12 Chemical Recovery Vessels Chapter 14 Redundant Propulsion and Steering Systems Chapter 15 Dynamic Positioning Systems Chapter 16 Harmony Class – Rules on Rating Noise and Vibration for Comfort, Cruise Ships (v ≤ 25kn)5 Chapter 17 Guidelines for Machinery Condition Monitoring Chapter 18 Harmony Class – Rules on Rating Noise and Vibration for Comfort, Cruise Ships (v > 25kn) Chapter 19 Guidelines for the Carriage of Refrigerated Containers on Board Ships Chapter 20 Stowage and Lashing of Containers Chapter 21 Ventilation Chapter 22 Guidelines for the Construction of Polar Class Ships Chapter 23 Harmony Class – Rules on Rating Noise and Vibration for Comfort, Cargo Ships Part 2 Inland Navigation Vessels Chapter 1 Classification and Surveys Chapter 2 Hull Design and Construction Chapter 3 Machinery, Systems and Electricity Chapter 4 Additional Requirements for Notations Part 3 Special Craft Chapter 1 High Speed Craft Chapter 2 Yachts ≥ 24 m Chapter 3 Yachts and Boats up to 24 m Chapter 4 Guidelines for Lifeboats ans Rescue Boats Chapter 5 Floating Docks Chapter 6 Preliminary Rules for Patrol Boats6 Part 4 Rigging Technology Chapter 1 Tall Ship Rigs Chapter 2 Guidelines for Design and Construction of Large Modern Yacht Rigs Chapter 3 Guidelines for the Type Approval of Carbon Strand and PBO Cable Rigging for Sailing Yachts Part 5 Underwater Technology Chapter 1 Diving Systems and Diving Simulators Chapter 2 Manned Submersibles Chapter 3 Unmanned Submersibles (ROV, AUV) and Underwater Working Machines Part 6 Offshore Service Vessels Chapter 1 Hull Structures Chapter 2 Machinery and Systems Chapter 3 Crew Boats and Offshore Wind Farm Service Craft II Materials and Welding Part 1 Metallic Materials Chapter 1 Principles and Test Procedures Chapter 2 Steel and Iron Materials Chapter 3 Non-Ferrous Metals Chapter 4 Equipment7 Chapter 5 Materials for Propeller Fabrication Chapter 6 Special Materials for Naval Ships Part 2 Non-Metallic Materials Chapter 1 Fibre Reinforced Plastics and Bonding Chapter 2 Wooden Materials Chapter 3 Guidelines for Elastomeric Adhesives and Adhesive Joints Part 3 Welding Chapter 1 General Requirements, Proof of Qualifications, Approvals Chapter 2 Design, Fabrication and Inspection of Welded Joints Chapter 3 Welding in the Various Fields of Application III Naval Ship Technology Part 0 Classification and Surveys Part 1 Surface Ships Chapter 1 Hull Structures and Ship Equipment Chapter 2 Propulsion Plants Chapter 3a Electrical Installations Chapter 3b Automation Chapter 4 Ship Operation Installations and Auxiliary Systems8 Part 2 Sub-Surface Ships Chapter 1 Submarines Chapter 2 Remotely Operated Underwater Vehicles Chapter 3 Guidelines for Air Independent Power Systems for Underwater Use IV Industrial Services Part 6 Offshore Technology Chapter 1 Classification, Certification and Surveys Chapter 2 Mobile Offshore Units Chapter 3 Fixed Offshore Installations Chapter 4 Structural Design Chapter 5 Machinery Installations Chapter 6 Electrical Installations V Analysis Techniques Part 1 Hull Structural Design Analyses Chapter 1 Guidelines for Global Strength Analysis of Container Ships Chapter 2 Guidelines for Fatigue Strength Analyses of Ship Structures 9 Part 2 Risk Analyses Chapter 1 Guidelines for the Analysis of Alternative Design and Arrangements VI Additional Rules and Guidelines Part 1 Container Technology Chapter 1 Guidelines for the Construction, Repair and Testing of Freight Containers Part 3 Machinery Installations Chapter 1 Guidelines for the Use of Gas as Fuel for Ships Chapter 4 Guidelines for Equipment on Fire Fighting Ships Chapter 5 Guidelines for Design, Equipment and Testing of Gas Welding Installations on Seagoing Ships Chapter 6 Guidelines for the Construction, Equipment and Testing of Closed Fuel Oil Overflow Systems Chapter 11 Guidelines for the Use of Fuel Cell Systems on Board of Ships and Boats Part 4 Diesel Engines Chapter 1 Guidelines for Mass Produced Engines Chapter 2 Guidelines for the Calculation of Crankshafts for Internal Combustion Engines Chapter 3 Guidelines for the Seating of Propulsion Plants and Auxiliary Machinery 10 Part 5 Pumps Chapter 1 Guidelines for the Design, Construction and Testing of Pumps Part 6 Modular Certification System Chapter 2 Guidelines for the Inspection of Mechanical and Electronical Products Part 7 Guidelines for the Performance of Type Approvals Chapter 1 Procedure Chapter 2 Test Requirements for Electrical / Electronic Equipment and Systems Chapter 4 Test Requirements for Sealing Systems of Bulkhead and Deck Penetrations Chapter 6 Test Requirements for Electrical Machinery Chapter 7 Test Requirements for Statical Converters with Semi-Conductors Chapter 8 Test Requirements for Components and Systems of Mechanical Engineering and Offshore Technology Part 8 Electrical Engineering Chapter 5 Guidelines for the Restoration of Electrical Systems following Damage caused by Fire, Water and Extinguishing Agents11 Part 9 Materials and Welding Chapter 2 Guidelines for the Fabrication and Inspection of Welded Pipelines of Copper-Nickel-Alloys Chapter 5 Guidelines for the Approval of Reaction Plastics and Composite Materials for the Seating and Repair of Components Part 10 Corrosion Protection Chapter 1 Coating of Ballast Water Tanks Chapter 2 Guidelines for Corrosion Protection and Coating Systems Chapter 3 Corrosion Protection of Crude Oil Cargo Tanks Part 11 Other Operations and Systems Chapter 2 Preliminary Guidelines for Safe Return to Port Capability of Passenger Ships Chapter 3 Guidelines for Sea Trials of Motor Vessels Chapter 4 Chamber Systems for Tunnelling Chapter 5 Guidelines for Extended Dry Dock Interval Chapter 6 Guidelines for the Preparation of Damage Stability Calculations and Damage Control Documentation on Board Chapter 7 Guidelines for Loading Computer Systems Chapter 8 Guidelines and Approval Procedure for “In Service Inclining Test Systems” (ISITS) Chapter 9 Guidelines for the Condition Assessment Program12 Chapter 10 Guidelines on Ballast Water Management Chapter 11 Guidelines for the Preparation of Operating and Maintenance Manuals for Shell Doors Part 12 Environment Protection Chapter 1 Guidelines for the Environmental Service System Part 13 Energy Efficiency Chapter 1 Guidelines for Determination of the Energy Efficiency Design Index IACS Common Structural Rules Bulk Carriers IACS Common Structural Rules Double Hull Oil Tankers IACS Common Structural Rules13
Germanischer Lloyd Rules ND and Programms 14.0
Platform: PC
Crack: Not needed
Tips and Tricks
I Ship Technology
GL Rules and Guidelines 4I Ship Technology 4
Tips and Tricks 14
I Ship Technology
Adhesive Joints
Part 3 Welding
Approvals
for Underwater Use
Container Ships
Ship Structures 9
and Arrangements
Part 5 Pumps
Testing of Pumps
Chapter 1 Procedure
Coating Systems
on Board
Bulk Carriers
GERMANISCHER LLOYD 2012
Download [43 KB]
Share
admin
Share
Share
Share
