Oligarca ®   10-Dec-2017 00:07
Machinery's Handbook 29th
Year: 2009
Author: ERIK OBERG, FRANKLIN D. JONES
Genre: Technical book
Pages count: 3915
Description: Machinery's Handbook has always been one of my favorite references. For anyone in the mechanical trades it is an indispensable source of knowledge, facts and figures. It includes everything from volume and beam stress formulas to the periodic table and how to apply SI metric standards. Need to know the density of oak or mahogany, or how about the constituents of forging brass? Machinery's has it all!
Machinery's has long been subtitled, "A Reference for the Mechanical Engineer, Draftsman, Toolmaker and Machinist". Unofficially it has been known as the Machinist's Bible and almost every machinist's and many mechanics tool chests have had a special top center drawer especially for Machinery's Handbook
Machinery's is so much a part of the engineering culture in North America that virtually every curriculum in metalworking and engineering has a required course on how to use Machinery's Handbook. Sadly many of these students do not learn to appreciate this solid gold reference and the used book market is often flooded with virtually new copies of Machinery's Handbook. As a basic reference it is as important to me as a good unabridged dictionary.
Change comes slow to such an encyclopedic reference published for nearly a century. New editions have been published every four years to keep up with changes in knowledge and technology. You can pick up a 5th Edition of Machinery's Handbook and it looks very similar to the 27th edition. From the 10th edition up they look almost identical. In fact many of the original articles and data that have not changed are still in this newest edition. However, technology does change and what was once important industrial practice is now the archaic.
The 27th edition has some of the biggest changes in its 90 year history. Most notably the organization and indexing. Besides the normal keyword index there are now additional indexes for Standards (11 pages) and for Interactive Equations (5 pages). Each major section of the book (divided at the thumb tabs) now has a table of contents. This makes the book much easier to navigate by subject.
Index
LICENSE AND LIMITED WARRANTY AGREEMENT ii
PREFACE v
TABLE OF CONTENTS vii
ACKNOWLEDGMENTS ix
MATHEMATICS 1
• NUMBERS, FRACTIONS, AND DECIMALS • ALGEBRA AND
EQUATIONS • GEOMETRY • SOLUTION OF TRIANGLES
• MATRICES • MANUFACTURING DATA ANALYSIS • ENGINEERING
ECONOMICS
MECHANICS AND STRENGTH OF MATERIALS 147
• MECHANICS • VELOCITY, ACCELERATION, WORK, AND ENERGY
• STRENGTH OF MATERIALS • PROPERTIES OF BODIES • BEAMS
• COLUMNS • PLATES, SHELLS, AND CYLINDERS • SHAFTS
• SPRINGS • DISC SPRINGS • FLUID MECHANICS
PROPERTIES, TREATMENT, AND TESTING OF MATERIALS 369
• THE ELEMENTS, HEAT, MASS, AND WEIGHT • PROPERTIES OF
WOOD, CERAMICS, PLASTICS, METALS • STANDARD STEELS
• TOOL STEELS • HARDENING, TEMPERING, AND ANNEALING
• NONFERROUS ALLOYS • PLASTICS
DIMENSIONING, GAGING, AND MEASURING 608
• DRAFTING PRACTICES • ALLOWANCES AND TOLERANCES FOR
FITS • MEASURING, INSTRUMENTS, AND INSPECTION METHODS
• SURFACE TEXTURE
TOOLING AND TOOLMAKING 754
• CUTTING TOOLS • CEMENTED CARBIDES • FORMING TOOLS
• MILLING CUTTERS • REAMERS • TWIST DRILLS AND
COUNTERBORES • TAPS • STANDARD TAPERS • ARBORS,
CHUCKS, AND SPINDLES • BROACHES AND BROACHING • FILES
AND BURS • KNURLS AND KNURLING • TOOL WEAR AND
SHARPENING
MACHINING OPERATIONS 1004
• CUTTING SPEEDS AND FEEDS • SPEED AND FEED TABLES
• ESTIMATING SPEEDS AND MACHINING POWER
• MICROMACHINING • MACHINING ECONOMETRICS • SCREW
MACHINES, BAND SAWS, CUTTING FLUIDS • MACHINING
NONFERROUS METALS AND NON-METALLIC MATERIALS • GRINDING
FEEDS AND SPEEDS • GRINDING AND OTHER ABRASIVE
PROCESSES • CNC NUMERICAL CONTROL PROGRAMMING
MANUFACTURING PROCESSES 1328
• SHEET METAL WORKING AND PRESSES • ELECTRICAL
DISCHARGE MACHINING • IRON AND STEEL CASTINGS
• SOLDERING AND BRAZING • WELDING • LASERS • FINISHING
OPERATIONS
TABLE OF CONTENTSTABLE OF CONTENTS
viii
Each section has a detailed Table of Contents or Index starting at the page indicated
FASTENERS 1517
• TORQUE AND TENSION IN FASTENERS • INCH THREADED
FASTENERS • METRIC THREADED FASTENERS • HELICAL COIL
SCREW THREAD INSERTS • BRITISH FASTENERS • MACHINE
SCREWS AND NUTS • CAP AND SET SCREWS • SELF-THREADING
SCREWS • T-SLOTS, BOLTS, AND NUTS • RIVETS AND RIVETED
JOINTS • PINS AND STUDS • RETAINING RINGS • WING NUTS,
WING SCREWS, AND THUMB SCREWS • NAILS, SPIKES, AND WOOD
SCREWS
THREADS AND THREADING 1802
• SCREW THREAD SYSTEMS • UNIFIED SCREW THREADS
• CALCULATING THREAD DIMENSIONS • METRIC SCREW
THREADS • ACME SCREW THREADS • BUTTRESS THREADS
• WHITWORTH THREADS • PIPE AND HOSE THREADS • OTHER
THREADS • MEASURING SCREW THREADS • TAPPING AND
THREAD CUTTING • THREAD ROLLING • THREAD GRINDING
• THREAD MILLING • SIMPLE, COMPOUND, DIFFERENTIAL, AND
BLOCK INDEXING
GEARS, SPLINES, AND CAMS 2122
• GEARS AND GEARING • HYPOID AND BEVEL GEARING • WORM
GEARING • HELICAL GEARING • OTHER GEAR TYPES
• CHECKING GEAR SIZES • GEAR MATERIALS • SPLINES AND
SERRATIONS • CAMS AND CAM DESIGN
MACHINE ELEMENTS 2310
• PLAIN BEARINGS • BALL, ROLLER, AND NEEDLE BEARINGS
• LUBRICATION • COUPLINGS, CLUTCHES, BRAKES • KEYS AND
KEYSEATS • FLEXIBLE BELTS AND SHEAVES • TRANSMISSION
CHAINS • BALL AND ACME LEADSCREWS • ELECTRIC MOTORS
• ADHESIVES AND SEALANTS • O-RINGS • ROLLED STEEL, WIRE,
SHEET-METAL, WIRE ROPE • SHAFT ALIGNMENT
MEASURING UNITS 2651
• SYMBOLS AND ABBREVIATIONS • MEASURING UNITS • U.S.
SYSTEM AND METRIC SYSTEM CONVERSIONS
INDEX 2701
INDEX OF STANDARDS 2789
INDEX OF INTERACTIVE EQUATIONS 2801
INDEX OF MATERIALS 2807
INDEX OF ADDITIONAL CONTENT ON THE CD 2854
ADDITIONAL ONLY ON THE CD 2865
• MATHEMATICS • MECHANICS AND STRENGTH OF MATERIALS
• PROPERTIES, TREATMENT, TESTING OF MATERIALS
• DIMENSIONING, GAGING, MEASURING, INSPECTION • TOOLING
AND TOOL MAKING • MACHINING OPERATIONS
• MANUFACTURING PROCESS • FASTENERS • THREADS AND
THREADING • GEARS, SPLINES, AND CAMS • MACHINE
ELEMENTS • ADDITIONALTABLE OF CONTENTS
DECIMALS
3 Fractional Inch, Decimal,
Millimeter Conversion
4 Numbers
4 Positive and Negative Numbers
5 Sequence of Operations
5 Ratio and Proportion
7 Percentage
8 Fractions
8 Common Fractions
8 Reciprocals
9 Addition, Subtraction,
Multiplication, Division
10 Decimal Fractions
11 Continued Fractions
12 Conjugate Fractions
13 Using Continued Fraction
14 Powers and Roots
14 Powers of Ten Notation
15 Converting to Power of Ten
15 Multiplication
16 Division
16 Constants Frequently Used in
Mathematical Expressions
17 Logarithms
17 Natural Logarithms
18 Imaginary and Complex Numbers
19 Factorial
19 Permutations
19 Combinations
20 Prime Numbers and Factors
ALGEBRA AND EQUATIONS
30 Rearrangement of Formulas
31 Principle Algebraic Expressions
32 Solving First Degree Equations
32 Solving Quadratic Equations
33 Factoring a Quadratic Expression
34 Cubic Equations
34 Solving Numerical Equations
35 Series
35 Derivatives and Integrals
GEOMETRY
37 Arithmetical & Geometrical
Progression
40 Analytical Geometry
40 Straight Line
43 Coordinate Systems
46 Circle
48 Ellipse
51 Spherical Areas and Volumes
54 Parabola
54 Hyperbola
66 Areas and Volumes
66 The Prismoidal Formula
66 Pappus or Guldinus Rules
67 Area of Revolution Surface
67 Area of Irregular Plane Surface
68 Areas of Cycloidal Curves
68 Contents of Cylindrical Tanks
70 Areas and Dimensions of Figures
76 Formulas for Regular Polygons
77 Circular Segments
80 Circles and Squares of Equal Area
81 Diagonals of Squares & Hexagons
82 Volumes of Solids
88 Circles in Circles and Rectangles
93 Circles within Rectangles
94 Rollers on a Shaft
95 Functions of Angles
96 Laws of Sines and Cosines
96 Trigonometric Identities
98 Right-angled Triangles
101 Obtuse-angled Triangles
103 Degree-radian Conversion
105 Functions of Angles, Graphic
106 Trig Function Tables
110 Versed Sine and Versed Cosine
110 Sevolute and Involute Functions
111 Involute Functions Tables
115 Spherical Trigonometry
115 Right Spherical Trigonometry
117 Oblique Spherical Trigonometry
119 Compound Angles
121 Interpolation
MATHEMATICSTABLE OF CONTENTS
MATHEMATICS
MATRICES
122 Matrix Operations
122 Matrix Addition and Subtraction
122 Matrix Multiplication
123 Transpose of a Matrix
123 Determinant of a Square Matrix
124 Minors and Cofactors
124 Adjoint of a Matrix
125 Singularity and Rank of a Matrix
125 Inverse of a Matrix
125 Simultaneous Equations
MANUFACTURING DATA
ANALYSIS
128 Statistics Theory
128 Statistical Distribution Curves
128 Normal Distribution Curve
128 Statistical Analysis
130 Applying Statistics
130 Minimum Number of Tests
130 Comparing Average Performance
132 Examples
133 Machinability and Hardness
ENGINEERING ECONOMICS
134 Interest
134 Simple and Compound Interest
135 Nominal vs. Effective Interest
Rates
136 Cash Flow and Equivalence
137 Cash Flow Diagrams
139 Depreciation
139 Straight Line Depreciation
139 Sum of the Years Digits
139 Double Declining Balance
139 Statutory Depreciation System
140 Evaluating Alternatives
140 Net Present Value
141 Capitalized Cost
142 Equivalent Uniform Annual Cost
143 Rate of Return
143 Benefit-cost Ratio
143 Payback Period
143 Break-even Analysis
146 Overhead Expense
Machinery_s_Handbook_29th_Edition.pdf
Download [8 KB]
Arcan   10-Dec-2017 08:17
Oligarca,It would be great if you will add 2-3 screenshots of some pages of this book and content, if possible.
And one more question:
"Seeder not seen: Never"
It seems, that you forget to download back your torrent file and add it to your client (µTorrent 3.4.6)
Thats is why nobody can download your file as it is non-visible to all clients.
Read carefully How to create NEW RELEASE and start SEEDING
Engineering trigonometry - Pease E.M.J., Wadsworth G.P. [1946, PDF]
Manual of Engineering Drawing - Colin Simmons, Dennis Maguire, Neil Phelps [2020, PDF]
Units & Symbols for Electrical & Electronic Engineers - The IET [2016, PDF]
Welding Handbook Volume 1, 2, 3 - American Welding Society [20XX, PDF]
Alfa Laval Pump Handbook 1st ed. [2001, PDF]
Marks’ Standard Handbook for Mechanical Engineers - Eugene A. [2000, PDF]
Marine Propellers and Propulsion Third Edition - J S Carlton FREng [2012, PDF]
Boat mechanical systems handbook. How to design, install, and evaluate mechanical systems - Dave…
eCalc (Scientific Calculator) v.1.5.1 [2009]
The time now is: Today 21:56
