vitbar192 ®   10-Jan-2020 13:43
Ekranoplanes - controlled flight close to the sea
Year: 2002
Author: Nebylov A.V, Wilson P.A.
Genre: Technical book
Publisher: WIT Press
ISBN: 978-1853128318
Format: DjVu
Pages count: 236
Description: This book is dedicated to the problem of flight control over the sea at low altitudes, and is concerned particularly with Ekranoplanes: a new breed of craft which use low resistance of ground effect flight. Under low flying conditions radar sensors measuring altitude, tilt and velocity of craft trace the variable profile of wave disturbance practically without averaging, thus making it difficult to gauge the motion parameters in relation to the undisturbed level of the sea surface. It is necessary to combine radar with other sensors in order to provide high accuracy. Translated from the original Russian, this volume will be of great interest to specialists in aviation and marine instrumentation, and researchers and designers of control systems for ekranoplanes, hovercraft, hydrofoils, helicopters, special purpose aircraft, search-and-rescue craft and other types of transport designed for motion close to the sea.
During flight basically at the height of the sea waves, radar sensors for altitude, tilt, and velocity of the craft trace the variable profile of the wave disturbance absolutely, without averaging. Therefore, it is difficult to measure the motion parameters in relation to the theoretical undisturbed level of the sea surface.
Nebylov A.V, Wilson P.A. Ekranoplanes - controlled flight close to the sea, 2002.djvu
Download [9 KB]
Radar and Electronic Navigation - G. J. Sonnenberg [1988, PDF]
Aerodynamics of sailing yachts - Giacobone F. [2017, PDF]
Wing-in-ground effect vehicles - Rozhdestvensky K.V. [2006, PDF]
Principles of Radio Navigation for Ground and Ship-Based Aircrafts - Sauta O.I. [2019, PDF]
Lectures On Ship Maneouvrability - Nikolai Kornev [2013, PDF]
Elements of hydrodynamic propulsion - J .A. Sparenberg [1984, PDF]
A High-Rate Virtual Instrument of Marine Vehicle Motions for Underwater Navigation and Ocean Remote ...
Control Valve Engineering - Sizing and Selection [2024, MP4]
Kite Dynamics for Ship Propulsion - G. M. Dadd [2012, PDF]
The time now is: Today 19:09
