NNT ®   02-Feb-2015 11:12
Lectures On Ship Maneouvrability
Year: 2013
Author: Nikolai Kornev
Edition: 1st
ISBN: 8740305597
Pages count: 177
Description: This book is dedicated to main principles of ship manoeuvrability. Experimental, theoretical and numerical methods used in the ship theory are presented in a clear and simple form.
The book is written on the base of a lecture course taught by the author at the Faculty of Mechanical Engineering and Marine Technology at the Rostock University in Germany.
Each chapter is supplied with exercises which can be solved either analytically or using software provided by the author. An optional chapter is devoted to wing in ground effect dynamics. The only prerequisite for the course is the knowledge of general fluid dynamics.
List of Tables
List of Figures
1 General differential equations of ship dynamics
1.1 Ship motion equations in the inertial reference system
1.2 Ship motion equations in the ship-fixed reference system
1.3 Ship motion equations in the ship-fixed coordinates with principle axes
1.4 Forces and moments arising from acceleration through the water
1.5 Exercises
2 Equations of ship manoeuvring with three degree of freedom
2.1 Coordi nate system
2.2 Alms of the ship manoeuvring theory
2.3 Main assumptions of the theory
2.4 Equations in the ship-fixed coordinates with principle axes
2.5 Munk moment
2.6 liquations In terms of the drift angle and trajectory curvature
2.7 Exercises
3 Determination of added mass
3.1 General solution
3.2 Added mass of the slender body
3.3 Added mass of the slender body at small Fn numbers
3.4 Exercises
4 Steady manoeuvring forces
4.1 Introduction
4.2 Representation of forces
4.3 Experimental determination of steady manoeuvring forces
4.4 Exercises
5 Calculation of steady manoeuvring forces using slender body theory
5.1 Force distribution on the slender body in the potential flow
5.2 Improvement of the slender body theory. Kutta condition
5.3 Exercises
6 Forces on ship rudders
6.1 Introduction
6.2 General representation of forces on the rudder
6.3 Determination of the force coefficients
6.4 Interaction between the rudder and propeller
6.5 Exercises
7 TVansversal forces and yaw moment on propeller
7.1 Additional transversal forces on propeller due to non-uniformity of the ship wake
7.2 Additional transversal forces on propeller due to oblique flow
7.3 Moment on the propeller due to upward oblique flow at the propeller location
7.4 Additional moments on the propeller during manoeuvring
7.5 Additional lateral force on the hull caused by propeller
7.6 Exercise
8 Yaw stability
8.1 Introduction
8.2 Linearization of the motion equations
8.3 Evolution of perturbations
8.4 Criterion of the stability
8.5 Influence of ship geometric parameters on the stability
8.6 Trajectory of a stable ship after perturbation
8.7 Steady ship motion in turning circle
8.8 Regulation of the stability
8.9 Exercises
9 Manoeuvrability Diagram. Experimental study of the manoeuvrability'
9.1 Stability at large drift angle and large angular velocity
9.2 Diagram O -
9.3 Manoeuvrability diagram
9.4 Experimental manoeuvring tests
9.5 Exercises
10 Influence of different factors on the manoeuvrability
10.1 Influence of the seaway
10.2 Shallow water effect
10.3 Influence of the wall on a mooring ship
10.4 Influence of the inclined wall or of inclined bottom
10.5 Control questions
11 Application of computational fluid dynamics for manoeuvrability problems
11.1 Introduction
11.2 Basic Equations
11.3 Computational grids
11.4 Exercises
12 Dynamics and Stability of Wing in ground effect craft (WIG)
12.1 Introduction
12.2 Criterion of the static stability of WIG craft and hydrofoils
12.3 Basic nomenclature and indices used in WIG dynamics theory
12.4 Representation of forces in WIG aerodynamics
12.5 WIG motion equations
12.6 Exercises
13 Bibliography
14 Appendix A Theory of irrotational flow
15 Appendix B Mirror principle
16 Endnotes
17 Index
LecturesShipManoeuvrability-2013
Download [7 KB]
Lectures on ship manoeuvrability - Prof. Dr.-Ing. habil. Nikolai Kornev [2019, PDF]
The Drift Force and Moment on Ships in Waves - J. N. Newman [1967, PDF]
Ship Dynamics for Mariners - I. C. Clark [2005, PDF]
Marine Propellers and Propulsion Third Edition - J S Carlton FREng [2012, PDF]
Naval Architecture for Marine Engineers: Volume 4 (Reed’s marine engineering series) - EA STOKOE…
SHIP RESISTANCE AND PROPULSION Second Edition - Anthony F. Molland, Stephen R. Turnock, Dominic A.
Water Waves and Ship Hydrodynamics: An Introduction - A. J. Hermans [2011, PDF]
Marine Hydrodynamics - J. N. Newman [2017, PDF]
A Study of Ship Manoeuvrability - R.P. Gokarn [2024, EPUB]
Parametric Roll Instability of Ships - Faculty of Mathematics and Natural Sciences University of…
The time now is: Today 16:48
