NNT ®   20-Apr-2015 07:12
Kite Dynamics for Ship Propulsion
Year: 2012
Author: G. M. Dadd
Genre: Research papers
Publisher: University of Southampton
Pages count: 215
Description: Kite propulsion has emerged as an attractive means to harness wind power in a way that yields environmental and financial benefits. An understanding of the dynamics that affect kite motion and the resulting forces is required to facilitate the design and optimization of kite propulsion systems.
In this thesis results from two line tension models are compared with experimentally recorded time histories for dynamic kite flight. New methodologies for investigating kite performance are established. The first zero mass model assumes that the kite and lines are weightless.
The second, lumped mass model, considers the kites mass and thus makes use of the equations of motion. It is found that the two
different models converge to the same result in the limit where the kite mass tends to zero. The zero mass model has been shown to compare favourably with experimental results. A method for parameterising figure of eight shape kite trajectories and for predicting kite velocity is presented. Results are shown for a variety of manoeuvre shapes, assuming realistic performance characteristics from an experimental test kite. Using a 320m 2 kite, with 300m long flying lines in 6.18ms −1 wind, a time averaged propulsive force of 16.7 tons is achievable. A typical kite force polar is presented and a new sensitivity study is carried out to identify the importance of various parameters in the system. Small horizontally orientated figure of eights shape kite trajectories centred on an elevation of 15 ◦ are preferred for maximising propulsive benefit.
Force is found to be highly sensitive to aspect ratio. Increasing aspect ratio from 4 to 5 is estimated to yield up to 15% more drive force.
Download [17 KB]
Wing Sail Performance Compared to a Traditional Sail on Sailing Craft - Turner H. [2015, PDF]
Marine Propulsion Simulation. Methods and Results - Martelli M. [2015, PDF]
Ship Motions and Capsizing in Astern Seas - S. J. Chou, et al [1974, PDF]
Numerical Modeling: Prediction of Ship Maneuvering and Hydrodynamics During Inland Waterway…
Guidance and Control of Ocean Vehicles - Fossen T.I. [1994, PDF]
Study and analysis of the use of wind power for the propulsion of merchant vessels. Case study. -…
Dynamics Modeling and Maneuvering of Autonomous Underwater Vehicles - Theory and Practice - Xiang…
Ship design-knowledge in early modern Europe - Royal yachts and the shared knowledge of…
Engineering Vibration - Daniel J. Inman [2014, PDF]
SHIP RESISTANCE AND PROPULSION Second Edition - Anthony F. Molland, Stephen R. Turnock, Dominic A.
The time now is: Today 16:47
