khany ®   23-Jan-2019 17:40
A High-Rate Virtual Instrument of Marine Vehicle Motions for Underwater Navigation and Ocean Remote Sensing
Year: 2013
Author: Chrystel Gelin
Genre: Textbook / Research book
Publisher: Springer International Publishing
Edition: 1
ISBN: 978-3-642-32015-6
Pages count: 112
Description: Dead-Reckoning aided with Doppler velocity measurement has been the most common method for underwater navigation for small vehicles. Unfortunately DR requires frequent position recalibrations and underwater vehicle navigation systems are limited to periodic position update when they surface. Finally standard Global Positioning System (GPS) receivers are unable to provide the rate or precision required when used on a small vessel. To overcome this, a low cost high rate motion measurement system for an Unmanned Surface Vehicle (USV) with underwater and oceanographic purposes is proposed. The proposed onboard system for the USV consists of an Inertial Measurement Unit (IMU) with accelerometers and rate gyros, a GPS receiver, a flux-gate compass, a roll and tilt sensor and an ADCP. Interfacing all the sensors proved rather challenging because of their different characteristics. The proposed data fusion technique integrates the sensors and develops an embeddable software package, using real time data fusion methods, for a USV to aid in navigation and control as well as controlling an onboard Acoustic Doppler Current Profiler (ADCP). While ADCPs non-intrusively measure water flow, the vessel motion needs to be removed to analyze the data and the system developed provides the motion measurements and processing to accomplish this task.
Additional info: Springer Series on Naval Architecture, Marine Engineering, Shipbuilding and Shipping Vol.1
C Gelin 2013.pdf
Download [4 KB]
Modern Inertial and Satellite Navigation Systems - Allonzo Kelly [1994, PDF]
Inertial Navigation Systems with Geodetic Applications - Christopher Jekeli [2023, PDF]
Principles of GNSS, Inertial, and Multisensor Integrated Navigation Systems - Paul D. Groves [2008, ...
Offshore Robotics: Volume I Issue 1 - Shun-Feng Su ,Ning Wang [2022, PDF]
Radar and Electronic Navigation - G. J. Sonnenberg [1988, PDF]
Mechanics of Marine Vehicles - B. R. Clayton, R. E. D. Bishop [1982, PDF]
Global Satellite Meteorological Observation (GSMO) - Applications, Volume 2 - Stojče Dimov Ilčev [20...
Springer Handbook of Global Navigation Satellite Systems - Various Authors [2017, PDF]
Radar Systems and Radio Aids to Navigation - A. K. Sen, A. B. Bhattacharya [2019, EPUB]
Measurement for the Sea | Supporting the Marine Environment and the Blue Economy - Pasquale Daponte ...
The time now is: Today 00:15
