virtual ®   22-Dec-2018 11:33
Code of Practice 7, The Safe Use of Oxy-Fuel Gas Equipment (Individual Portable or Mobile Cylinder Supply), Revision 8
Year: 2018
Author: BCGA
Pages count: 56
Description: This Code of Practice has been prepared by the British Compressed Gases Association (BCGA) to provide guidance on the safe use of oxy-fuel gas equipment, each gas being supplied from a cylinder and individually controlled by a cylinder-mounted pressure regulator.
Gas cylinders are designed and constructed to safely contain a gas under pressure. Used with the correct downstream pressure equipment they provide an efficient and effective means of delivering a gas to the end process.
Oxy-fuel gas equipment has many uses, including welding, cutting, heating, straightening, and descaling. The equipment is versatile and relatively easy to move and use, however, it also has its hazards and consequently its use is governed by several Regulations.
BCGA CP 7 - Rev 8 - For Publication-1.pdf
Download [936 B]
Code of Practice 6, The Safe Distribution of Acetylene in the Pressure Range 0 - 1.5 BAR, Revision 3...
Code Of Practice 5, The Design and Construction of Manifolds using Acetylene Gas from 1.5 to 25 Bar,...
Code of Practice 18, The Safe Storage, Handling and Use of Special Gases, Revision 3 - BCGA [2014, P...
Code of Practice 4, Industrial Gas Cylinder Manifolds and Gas Distribution Pipework (excluding Acety...
MAN B&W Low Speed Small Bore Engines Now with Electronic Control - MAN [2014, PDF]
Guidance Note 34, The Safe Use of Gases in the Steel industry - BCGA [2018, PDF]
Compressed Gas Cylinders Safety [2022, MP4]
Bridge Procedures Guide (OCR) - ICS [2016, PDF]
Methanol Bunkering: technical and operational advisory - ABS [2024, PDF]
Pressure regulators, K-Series - Gloor - Emerson - Medenus & Festo - Various [2018, PDF]
The time now is: Today 03:47
