Year: 2022 Language: english Playtime: 0h 32m Quality: WEB-DL Format: MP4 Video: H.264 1280x720 30 fps Audio: AAC 48.0 KHz x 320 Kbps Description: Safe use, handing, transport and storage of compressed gas cylinders in terms of precautions to be taken What you'll learn Learn about key Hazards associated with Compressed gas cylinders Few gases used commonly in construction industries and their characteristics What are the Conditions to store gas cylinders safely? How to carry out the Inspection of gas cylinders before use? How to manage damaged gas cylinders? Summary of safe use, transport, storage and handing of compressed gas cylinders Requirements Basic knowledge on construction, able to understand English, knowledge on welding and cutting Description This course is created to improve the awareness on safe use of compressed gas cylinder in construction industry. Many fire and explosion incidents do happen commonly at construction industry. The root causes of the incidents area) Lack of knowledgeb) Inexperienced operatorsc) Lack of inspection and maintenance of gas cylindersd) Uncontrolled hot worke) Unsafe handling of gas cylinders and hose pipesf) Unsafe storage of gas cylindersg) Not prepared for emergency situation such as fire and explosionh) Not performing Hydro test on the cylinders to check its condition periodically.In this course,As far as practically possible, the course materials are prepared with lot of pictures clicked at the construction sites are added.Chapter 1- Introductions and objectives of the course is explainedChapter 2- The learner will be able to understand the hazards arising due to use, handling and storage of gas cylinders. Also learn about the characteristics of various gases commonly used in construction industry. Color codes for the gas cylinders used within European codes are explained in this chapter.Chapter 3- In this chapter, hazards of Oxygen and Acetylene is explained. Also, the hazard due to oxygen enrichment is briefed with prevention measures for such enrichment.Chapter 4- The learner will be able to understand how to identify the gas cylinders and the precautions to be taken during supply and transportationChapter5 – In this chapter, the safe storage of gas cylinders and safe securing of cylinders are explained illustratively.Chapter 6- In this chapter, the explosion proof requirement of electrical equipment used at the storage of gas cylinders is well explained. Also, the inspection and care of the hose pipes used for Oxygen- Acetylene cutting set is briefedChapter 7– The learner will be able to understand about the don’ts about the handling of gas cylinders, care for the cylinders and the importance of cleanliness of gas cylinders.Chapter 8 – This chapter explains about the general precautions to be taken for the prevention of fire and the use of gases inside confined space.Chapter 9 – The learner will be able to understand about the regulator checks on the cylinder and how to remove the damaged cylinders safely out of service. Also, how to execute the hot work safely to protect the surrounding services.Chapter 10 – In this deck, the summary of all precautions is briefed at a glance. Overview Section 1: Introduction Lecture 1 Introduction Section 2: Compressed gas cylinder safety - Part2 Lecture 2 Compressed gas cylinder safety - Part 2 Section 3: Compressed gas cylinder safety- Part3 Lecture 3 Compressed gas cylinder safety- Part3 Section 4: Compressed Gas Cylinder- Part4.mp4 Lecture 4 Compressed Gas Cylinder safety- Part4 Section 5: Compressed Gas cylinder safety- Part5 Lecture 5 Compressed Gas Cylinder- Part5 Section 6: Compressed Gas Cylinder safety- Part6 Lecture 6 Compressed gas cylinder-Part6 Section 7: Compressed Gas Cylinder safety- Part7 Lecture 7 Compressed gas cylinder-Part7 Section 8: Compressed gas cylinder safety-Part8 Lecture 8 Compressed gas cylinder- Part8 Section 9: Compressed gas cylinder safety- Part9 Lecture 9 Compressed gas cylinder safety- Part 9 Section 10: Compressed Gas Cylinder safety- Part 10 Lecture 10 Compressed Gas cylinder Safety -Part 10 Safety officers, welders , cutters, Supervisors, construction safety officers, Construction Engineers and Project Managers
Compressed Gas Cylinders Safety
Playtime: 0h 32m
Quality: WEB-DL
Format: MP4
What you'll learn
Requirements
Description
Overview
Compressed Gas cylinders safety
Download [22 KB]
Share
