Punky ®   11-Nov-2018 08:45
Transas 4000 Navi-Planner 2017
Year: 2017
Version: 3.01.347.0134
Developer: TRANSAS
64-bit OS compatibility: yes
System Requirements: Windows 7,8,10 x32 or x64
Microsoft .NET Framework 3.5 (which includes .NET 2.0 and 3.0) should be installed, otherwise it can be downloaded by installation software.
Adobe Reader => 9.04 or will be installed by installation software.
Localization: multilingual
Crack: N/A
Description: Navi-Planner 4000 is recognized as the ECDIS markets most powerful charts management application, and also a set of databases, applications and services
intended for voyage planning. Suitable both onboard as a ’back of the bridge’ application, and ashore as a management tool Navi-Planner 4000 software creates a voyage plan using an electronic route editor, including:
•Port to port planning of a complete voyage plan
•AtoBviaC auto routing
•Under Keel and Over Head Clearance
•Route checking•Reference point selection
•Reporting points•Warnings along the route
•Chart listings for both (S)ENC and paper charts
•Detailed voyage plan reports
•Route export/import
•Integration with Navi-Sailor 4000 ECDIS
•Online correction service for paper charts and publications via TGT Services
Additional info: This release include installation of version TPT 73 - 3.00.347.0053 (2016) and upgrade to version TPT 75 - 3.01.347.0134 (2017).
This version can be used with charts and routes, which kindly was released by Ustjur in this release.
Manual for Navi-Planner can be found here, kindly released by NNT
Many thanks to Ustjur and NNT.
If it really help you or you just like this release - don't forget to push "Thank U" button!
Download [13 KB]
Sot   18-Nov-2018 21:11
Pls exlain the instalasion because the app ask license and not open
Arcan   23-Nov-2018 11:54
Installation is the same as explained in THIS release.
Moreover, at least two video exist re installation of Navi Planner : here and here. Watch it carefully and follow it.
Punky ®   28-Nov-2018 06:34
For those having an error popup regarding pureslave server “....due to multiple connections” when trying to start the software: exit the pureslave server from system tray and start Navi-Planner againg.
Enjoy!
tomdebu   13-Dec-2018 21:46
Facturamea83,
Hi, what do you mean "exit pureslave server from system tray" ? how to do that?
Punky ®   15-Dec-2018 06:31
Hi tomdebu,
That is only when you have installed Navisailor 4000 as well. If you have only naviplanner is not neccessary.
Regrds
paxtu   21-Dec-2018 01:17
Hi, how can I connect the gps to the program, I tried it and I could not.
Thank you Матрос Матрос
Htet_Naing   21-Jan-2019 03:43
SirArcan, Can you instruct me to Download Transas Navi-Planner 4000 with Auto Route License because above one is without Auto Route License. Thanks for helping.
7
Punky ®   21-Jan-2019 09:16
Htet_Naing, autoroute will be functional only if you change your PC date to 2014. Change PC date, create the route and save it. After that you can change back your PC date to current date and use the route.
Regards!11
Punky ®   21-Jan-2019 09:35
paxtu, you can connect only if you have NaviSailor installed as well.
Helene1524   01-Apr-2019 13:33
I read all Posts and even from the other topic, but I still Dont understand the license thing..... the zip file ‘license” is empty if thats the one they mean...... so right now when I try to open the program it says no license
Thanks in advance (:
3
Transas 4000 Navi-Planner v.2.0 - Transas [2015]
Navi-Planner 4000. VirtualBox Workstation with Win 7(En) x86 (Lite) v.2.0.344 (build 0016) - TRANSAS...
Wartsila (Transas) World Folio, Issue WF 89SE, Main & Auxiliary Collection DVD - Wartsila [2020]
Wartsila (Transas) World Folio, Issue WF 90SE, Main & Auxiliary Collection DVD - Wartsila [2020]
Wartsila (Transas) World Folio, Issue WF 97SE, Main & Auxiliary Collection DVD (Tx97) with NE v.WF_9...
Navi-Planner CBT v.2.0 [2014]
Wartsila (Transas) TX-97 Marine Charts - World Folios Collection
ChartWorld Route Converter v.1.0.0.23 - ChartWorld [2021]
The time now is: Today 15:58
