Arcan ®   25-Feb-2018 12:04
Navi-Planner 4000. VirtualBox Workstation with Win 7(En) x86 (Lite)
Year: 2015
Version: 2.0.344 (build 0016)
Developer: TRANSAS
Platform: Any platform with ability to install VirtualBox
64-bit OS compatibility: yes
System Requirements: VirtualBox installed with RAM 2048 mb and video memory 32 mb at least. Use downloaded file as Virtual disk.
Crack: Included
Description: Here is virtual engine with installed Navi-Planner. You can use it for learning purposes only.
With this software you can do:
- Handling of Routes and Schedules
- Handling of Voyage Plan
- Handling of Electronic Charts and Chart Information
- Handling of Maps
- Handling of Tides and Currents
- Handling of Weather Forecasts
- Handling of Piracy Data
More information how to do all above tasks you can find in the manual or in the CBT
Additional info: Thanks to Ustjur
When you will be asked for Connection to Pure Slave Server - just press Cancel button.
Download [19 KB]
cvaigon   25-Feb-2018 15:51
Люди, кому не жалко времени , скиньте в "личку" снимок с экрана- район Обской губы (Новый порт и Сабетта )в максимальном увеличении, заранее спасибо.................
Если,конечно , кому-то удалось установить "сие чудо"....................
cvaigon   25-Feb-2018 16:07
И еще интересует, наличие карт в это программе- р.Обь ,от "Хантов" до Томска....................
kav-des   12-Apr-2018 19:24
Доброго времени суток! Дайте пожалуйста скачать, 70% загрузилось и никого нет.
Arcan ®   13-Apr-2018 08:04
alper555, First of all - type in Google "Oracle VirtualBox", then go to site and read carefully - what is this "Oracle VirtualBox" and how to use it. And only after that, probably, you will have a wish to open the file.
jamilcea   13-Nov-2018 03:01
How to install this file. Cant load it in virtualbox. Can someone pls send instructions for installation.
3rdmate999   24-Jan-2019 14:28
Доброе время суток можете дать инструкцию как открыть ваш файл с помощью VirtualBox-5.2.24-128163-Win
Arcan ®   24-Jan-2019 15:20
3rdmate999, Это похоже, что у вас уже была виртуальная машина с таким названием и использованным диском. Вы ее некорректно удалили. Чтобы воспользоваться - надо найти программу CloneVDI и прогнать через нее скачанный файл с опцией "Generate new UUID".
А вообще то откройте указанный на картинке файл (лог) и почитайте, что там написано про ошибки открытия.
3rdmate999   24-Jan-2019 16:14
Еще раз здравствуйте, можете только сказать что для работы Navi planera мне необходимо создать виртуальную машину с Windows 7 и потом добавить на нее ваш файл NP_Win7LiteEN.vdi
3rdmate999   24-Jan-2019 16:46
Появилась очень неприятная проблема: запускаю нави планер и когда хочу создать новый роут скролом хочу посмотреть глобальную карту мира - вырубает комп, уже два раза так. Синий экран пишет вроде физической памяти не хватает. Не знаете что сделать нужно?
Arcan ®   24-Jan-2019 18:11
3rdmate999, Я думаю, правильно настроить виртуальную машину.
3rdmate999   24-Jan-2019 23:06
а можете скинуть ссылку на Navi planer и карты попробую сам установить на VMware Workstation Pro
-4
Helmsman87   01-Apr-2019 22:24
Arcan, функция Auto Route не работает - при нажатии на соответствующую клавишу ноль реакции. Не подскажете, как-нибудь можно вылечить?
Navi-sailor 3000. VirtualBox Workstation with Win 10(En) x64 + WF61 Fixed v.4.00.10 [2008]
Navi-sailor 3000 ECDIS-I VirtualBox Workstation with Win 10-x64 + WF91 FAR EAST ONLY (ZR05) !!! - Tr...
Transas 4000 Navi-Planner 2017 v.3.01.347.0134 - TRANSAS [2017]
Wartsila (Transas) World Folio, Issue WF 97SE, Main & Auxiliary Collection DVD (Tx97) with NE v.WF_9...
Transas 4000 Navi-Planner v.2.0 - Transas [2015]
Chart Planner v.3 [2016]
Transas Navi Sailor 4100 + MFD v.2.00.320 - Transas [2011]
The time now is: Today 06:19
