Ustjur ®   23-Feb-2018 00:49
Transas 4000 Navi-Planner
Year: 2014
Version: 2.0
Developer: Transas
64-bit OS compatibility: да
System Requirements: Win-XP/7/8/8.1/10
Localization: english, russian
Crack: Yes
Description: Navi-Planner 4000 is recognized as the ECDIS markets most powerful charts management application, and also a set of databases, applications and services intended for voyage planning. Suitable both onboard as a ’back of the bridge’ application, and ashore as a management tool Navi-Planner 4000 software creates a voyage plan using an electronic route editor, including:
•Port to port planning of a complete voyage plan
•AtoBviaC auto routing
•Under Keel and Over Head Clearance
•Route checking
•Reference point selection
•Reporting points
•Warnings along the route
•Chart listings for both (S)ENC and paper charts
•Detailed voyage plan reports
•Route export/import
•Integration with Navi-Sailor 4000 ECDIS
•Online correction service for paper charts and publications via TGT Services
HowTo
1.Unpack and Install programs Navi-Planer Transas 4000
During installation, whenever you will be asked : Standalone product or Connected to MFD - select Connected to MFD and type Gateway host/IP: 127.0.0.1
If you will be asked for rebooting of your PC - reboot it.
2. Two files from the folder Licensed - copy in a folder, where you installed NAVI-PLANER, with the replacement of original. Usually it is C/Transas/PS4000 folder
3. Install sentinel protection, then install emulator for win64 (add 057f.reg to windows registry, then Install.bat from administrator rights) or run emulator for win32 (sentemu).
All the program works for 2015 to 2016 if someone wants to translate the date
put Ranesadate is in the folder or throw new license files taken from the enterprise.
4. Now we copy files with charts and with the license for these charts till 2015 are also taken. If somebody
would like to download newer charts - it can done with a new license, but for planning routes and calculating the distanses
these are enough.(C/Transas/PS4000)/Collections/Charts/Local/ copy all files from a folder "c.CHARTS.00000186161110083529"
5. Who are too lazy to make up a route in the program there is a quick itinerary planning
or to copy old routes for examples for to load them from the program. Copying
should be from the folder "c.ROUTE.00000186160771998734" to C/Transas/PS4000/Collections/Route/Rev0000000B.
Have at least 6 feet under the keel!!!
Download [15 KB]
Arcan   23-Feb-2018 06:32
Ustjur, Registered: 5 hours | Completed: 0 times
Seeder not seen: Never
Скачайте с сайта себе обратно торрент файл и добавьте именно его в свой клиент (utorrent).
Если выскочит вот такое окно:
согласитесь, просто нажав "Да".
И не забудьте, что ваш клиент должен быть запущен и в сети, по крайней мере до того, как ваш файл скачают 2-3 раза.
Arcan   23-Feb-2018 12:25
Ну, наконец то скачалось.
Проверяем в работе, отписываемся.
kadoka   23-Feb-2018 12:42
Hi
Great soft.Would be possible to give English installaion.
Best regards
Ustjur ®   23-Feb-2018 14:19
2. Two files from the folder Licensed- to copy in a folder with the replacement where you installed NAVI-PLANER.
3. Install sentinel protection put it for win64 (Install bat) or for win32
9
Arcan   23-Feb-2018 15:37
Ustjur, Маленько подправил картинки - сделал реальные скриншоты с установленной программы.
kadoka   23-Feb-2018 19:04
From English instruction installation I don't understand point No. 4.Can someone explain me more how to install it because when I completed installation programme ask me about dungle.
Ustjur ®   23-Feb-2018 19:52
No4; The license only valid for 2015 needs to change the date on the computer back for 2015, after when the program Navi-Planer will working to change date by the program (Runasdate)
mircea   24-Feb-2018 11:18
I don`t see the charts.Where must copy the chharts?How to update license?
Arcan   24-Feb-2018 12:06
mircea, Read "HowTo:"
If somebody would like to download newer charts - it can done with a new license, but for planning routes and calculating the distanses
these are enough.
nisshutsu   27-Feb-2018 10:34
Is the AtoBviaC auto routing function working in this copy of Navi-Planner?
Arcan   27-Feb-2018 12:27
nisshutsu, Read carefully manual, page 48:
"Switch to Route Editor tab and press Auto route button in Create Route group.
In the window, which will open up, press From Port button and from the drop-down list select the port of
departure.
Press To Port button and from the drop-down list select the port of destination.
In the Via drop-down list, select geographic points (ports, straits, channels, etc.) which the route should pass
through. These points are set in the Routing Options group.
Press Calculate button.
Merciless   28-Feb-2018 00:59
Arcan, Sir, can the Transas naviplanner be installed on the same drive with the Navisailor 3000 ECDIS??
Arcan   28-Feb-2018 08:01
Merciless, Well, it can be installed, but as a separate software with using separate charts for which license is issued.
Merciless   28-Feb-2018 18:12
Ustjur, Sir can post a video on how to install this program? Just cannot get through with it. While installing it asks for the licence, but when I point it to the folder with the licence it says invalid. pls help me.
ChartWorld Route Converter v.1.0.0.23 - ChartWorld [2021]
VR Tool v.4.1.1 - Omar Reis [2022]
Passage Manager 6.0 + MetManager 7.0 - ChartCo [2016]
Chart Planner v.3 [2016]
ADMIRALTY Digital Catalogue (ADC) v.1.8.8 - UKHO [2026]
Marine Online - ECDIS Voyage Planning [2016, MP4]
Wartsila (Transas) World Folio, Issue WF 90SE, Main & Auxiliary Collection DVD - Wartsila [2020]
The time now is: Today 18:45
