zxc ®   16-Feb-2014 15:59
SELCO Generator Controls and Alarm Annunciators
Year: 2007
Author: SELCO A/S
Publisher: SELCO A/S
Format: HTML
Number of pages: >100
Contents:
  • Introduction
  • Products
  • Manuals
  • Software
  • Applications
  • Slideshows
  • Representation
  • Contacts
Introduction
SELCO #59
New Integrated Generator Protection and Control System “SIGMA”
SIGMA is a brand new product line combining an integrated and modular approach to modern generator protection and control.
T7900 Electronic Potentiometer
Since the origin in 1960, SELCO A/S technology has provided the electrical power generation market with high class equipment used for generators on board ships and in compact land-based power stations where operation in parallel.
Arc Detecting and Protection System.
SELCO manufactures and supplies electronic relays and microprocessor based equipment for control, monitoring and protection of medium sized generators in parallel operation.
SELCO products are marketed and sold in more than 60 countries worldwide.
SELCO offers a comprehensive range of services including technical support, applications support and spare part services. SELCO staff and its partners worldwide take pride in exceeding their custo­mers’ expectations in their quality and excellent service.
SELCO also manufactures a wide range of alarm annunciators, indicator panels and software for use in a variety of marine and land-based applications.
The process industry is one type of land-based application. All products undergo thorough test and inspection procedures to ensure high reliability and continuous operation in the field.
The SELCO equipment has been thoroughly tested by certified laboratories with regard to high vibration levels, heat, cold, humidity, salt mist, EMC emission and immunity as well as other parameters. SELCO products are in accordance with all significant international standards and have been approved and certified by the major marine classification societies, including Lloyds Register of Shipping, Germanischer Lloyd and Det Norske Veritas.
The SELCO philosophy is to offer easy-to-install, serviceable and reliable modular system components for mounting on switchboards and control consoles. Systems based on such components provide high flexi­bility, easy troubleshooting and require very little maintenance and service, which give our customers a low Total Cost of Ownership (TCO).
You may also visit our homepage www.selco.com . Our Internet Guide may give you useful information on how to find the data you need.
Products
The full SELCO product-line is available through the data-sheets in this section. Simply choose the subject you wish to view, e.g. Synchronizing and Load/ Power Control, and the data-sheets regarding this subject are then available sorted by the product number, e.g. "T4500 Auto Synchronizer, for conventional governors".
Alternatively you can choose the data-sheet directly, if you know the product number, by entering the "Complete product list" below.
The data sheets are stored in PDF format. In order to view and print PDF files, you must have the Adobe Acrobat Reader installed on your computer.
Acrobat Reader can be downloaded free of charge by clicking on the icon below.
Get Acrobat Reader
Short Form Overview
Alarm Annunciators and Indicators
Synchronizing and Load / Power Control
Power Management
SIGMA Protection & Control
Engine Starting and Management
Protective Relays and Systems
Power Monitoring Units
G-Line Generator Protection Relays
Arc Detecting & Protection System
Spare Parts
Complete Product List
Full Product Overview
Text Labels
Type Approvals
Manuals
dditional to the data-sheets some SELCO units have different setups that can be altered for different applications needed. These are described detailed in the following files, with step by step setup routines and programming schemes.
All manuals are in PDF Adobe Acrobat Reader format. In order to view and print PDF files, you must have the Adobe Acrobat Reader installed on your computer.
Get Acrobat Reader
G0100 Programming Kit for G-Line Relays and T7900 Elec. Potentiometer
H0300 Event Logger
H2000 Engine Controller
H3000 Analog Alarm Annunciator
H3100 Indicator Panel
HyperTerminal for SELCO Products
Interfacing the T4000 and T4400
M1000C RS232 Configuration
M3000 Analog Alarm Annunciator
M3092 Programmer Manual
MODBUS Protocol for SELCO Alarm Annunciators and Indicator Panel
N0300 Process-Logger
S6000 Additional Info
S6100 Additional Info
S6500 Additional Info
S6600 Additional Info
S6610 Additional Info
Software
PC SOFTWARE
From this section you can install various software programs for use with SELCO products.
N0300 Process logger
N0500 M-Programmer
M3092 Programmer for M3000
Process Logger N0300
Process Logger N0300 provides PC based logging of alarms and events on the Alarm Annunciators M1000 and M3000, the Engine Controller M2000 and the Emergency Controller M2100. The N0300 is capable of monitoring and control of up to 62 units. Logging can be performed on screen, printer and harddisk and includes description of each event with related date and time. The SELCO N0300 software includes functions for monitoring and start/reset of each unit.
The units are connected to the RS485 bus via a 3-wire bus cable, where the maximum length of the bus cable is 1000 metres. The adaptor M0300 is an RS485 / RS232 converter. The connection between the adaptor and PC can be a direct link, a radio link or via the public telephone lines.
The full program program can be installed by clicking on the link below.
Install N0300 Process logger
M-Programmer N0500
M-Programmer N0500 is configuration software that expands the number of programming options for the Engine Controller M2000, Emergency Controller M2100 and Alarm Annunciator M1000. The software is a part of Test/Demonstration Boards M1045, M2045 and M2145. M1000, M2000 and M2100 should mounted in the appropriate testboard before programming.
In order to install the program click on the link below.
Install N0500 M-Programmer
Programmer M3092
Programmer M3092 is a Windows program for setting up the parameters in the M3000 via the RS232 interface. The functions of the are further described in the Help-section of program.
Install M3092 Programmer
Applications
Following are some applications diagrams for load sharing, co-production etc. The diagrams show examples of how to use the SELCO units together in various solutions, with detailed connection diagrams.
All diagrams are in PDF Adobe Acrobat Reader format. In order to view and print PDF files, you must have the Adobe Acrobat Reader installed on your computer.
Get Acrobat Reader
M1000 used as repeating panel
Single generator - uninterrupted suppy
Generator protection
Synchronization and load sharing, T4500, T4800 & conventional gov.
Synchronization and load sharing, T4500, T4800, E7800 & electronic gov.
Synchronization and load sharing, T4500, T4800, T7900 & electronic gov.
Synchronization and load sharing, T4000, T4400 & electronic gov.
Synchronizing two generators simultaneously to the grid
Active- and reactive load sharing
Co-Generation, Application Note
Co-Generation, constant generator load
Co-Generation, single generator, constant grid load
Co-Generation, multiple generators, constant grid load
Co-Generation, multiple generators, constant grid power factor
Sigma Application Diagrams
Sigma - T4500, synchronizing generators simultaneously to a shaft generator
Load depending start and stop, synchronizing and load sharing
Power management system, synchronizing and load sharing
Arc Detecting Relay (DC) plus two Junction Boxes
Arc Detecting Relay (AC) plus two Junction Boxes
Slideshows
Several slideshows are available from this section ranging from Generator Protection to Engine Controls and Alarm Annunciation.
All slideshows are in MS PowerPoint format. The slides are advanced on mouse click. The full SELCO slideshow is set up to loop continuously.
Company Profile gives a general overview of SELCO and our products.
Show the Company Profile slideshow
Alarm Annunciators describes the popular M1000 and M3000 Alarm Annunciators, offering flexible alarm monitoring for both digital and analog inputs. Also the SELCO range of Indicator Panels is described.
Show the Alarm Annunciator slideshow
The SELCO H0300 Event Logger is a compact stand-alone unit capable of logging events from the SELCO M1000 & M3000 Alarm Annunciators, and the SELCO M4700-80 & H1500 Indicator Panels.
Show the Event Logger slideshow
Synchronizing & Load Sharing gives various examples on how to synchronize and share the load between gensets. Instruments for conventional governors as well as electronic governors are described.
Show the Synchronizing & Load Sharing slideshow
The new SELCO T7900 Electronic Potentiometer is typically used as an interface between increase and decrease contacts and e.g. an electronic speed controller requiring control / adjustment by a voltage or current signal.
Show the Electronic Potentiometer slideshow
Co-generation is becoming an increasingly important issue in the electricit6y market. Various setups for importing and exporting power to the grid are described.
Show the Co-generation slideshow
Power Management shows the combination of the SELCO products for power management of several gensets.
Show the Power Management slideshow
SIGMA is a new integrated generator protection and control system from SELCO. Ease of use, quality and cost effectiveness keywords for the SIGMA system.
Show the SIGMA slideshow
Engine Controls gives a description of products for engine controls and protection, including emergency engine controls and protection.
Show the Engine Control slideshow
Monitoring and Protection Relays gives a total overview of the SELCO T-Line units for monitoring and protection of gensets and busbars.
Show the Monitoring and Protection Relays slideshow
SELCO´s new G-Line Generator Protection Relays are mainly intended for use in land-based applications. The G-Line range of relays provides an efficient solution in applications where cost of materials is the main issue.
Show the G-Line slideshow
SELCO´s Arc Detection and Protection System is based on experience with arc protections since 1962. The Arc Detecting Relay is connected to light sensitive detectors, placed in the various cubicles or drawers inside the switchboard.
Show the Arc Detection slideshow
The full SELCO slideshow is a combination of all the above slideshows. This slideshow is setup to loop continuously.
Show the full SELCO slideshow
Файл образа .nrg монтировать и открывать с помощью Alcohol, Deamon Tools
SELCO.nrg
Download [19 KB]
SEA DOG   15-Jan-2021 15:30
Станьте кто-нить на раздачу злыдни:))) Не могу уже какой день скачать.
DataChief C20 - Alarm and monitoring system with process control and power management (Instruction…
Troy Marine Fire Safety Product Solutions - TROY [2014, PDF]
Судовая станция пожарной сигнализации - Autronica / Fire Alarm Sistem BS-100/2 Samsung/1139 [1995,…
The Tufmon MEV282…Oil Mist Detector/Manual Instruction [PDF]
CD-26-1 HV (HIGH VOLAGE) ELECTRICAL EQUIPMENT (Maritime Electronic Library) - ERMO83 [2011, PDF]
Diagnos & Programmer 3 v.2.46.1 - Scania [2021]
The time now is: Today 17:46
