planet-yur ®   05-Jun-2013 18:27
Станция пожарной сигнализации/Fire Alarm Sistem BS-100/2 Samsung/1139
Year: 1995
Author: Autronica
Genre: Documentations
Publisher: Autronika Representantives
Number of pages: 302
Description: Applications :
Fire alarm control panel type BS-100 DYFI ®is a control panel for analogue addressable fire detectors for medium and larger installations. DYF!'( Dynamic Filter Process) is the registered name for a number of dynamic fillers built into the BS-100 software that ensure discrimination between "real" fire conditions and otlier "non-fire" phenomena. . Features Standard unit includes two detector loops, each allowing connection of up to 99 addresses.
Additional modules can be added to allow a total of 16 loops (1584 addresses). "Pre-warning" enables the system to inform about a fire, in its earliest stages. Faulty, damaged or missing detectors are reported without compromising the system. User controls through multi-level menu.
Fire alarm control panel type BS-tttO DYFI ®is a control panel for analogue addressable fire detectors for medium and larger installations. DYF!'( Dynamic Filter Process) is the registered name for a number of dynamic fillers built into the BS-100 software that ensure discrimination between "real" fire conditions and otlier "non-fire" phenomena.
Features Standard unit includes two detector loops, each allowing connection of up to 99 addresses. Additional modules can be added to allow a total of 16 loops (1584 addresses). "Pre-warning" enables the system to inform about a fire, in its earliest stages. Faulty, damaged or missing detectors are reported without compromising the system. User controls through multi-level menu.
All detectors and manual callpoints have a unique address. Multiple microprocessor control for increased reliability. Cause and effect, and message data stored in nonvolatile memory with on-site changing capability. Monitoring of all field devices and alarm path. Optional programmable control outputs, in modules of 16 to a maximum of 240 outputs. RS232C and 20 mA current loop interface for data communication to remote text or graphics displays, repeaters or building management systems. 2 x 40 character fluorescent dot-matrix alphanumeric display for clarity.
Detector or loop disablement with timed automatic or manual restoration. Historical event logging. On optional printer, all; events and changes of status are printed. Day/night alarm organisation facility. Self-diagnosis of "fault" condition.
Sensitivity of all devices easily examined. Reduces maintenance costs due to inherent reliability. Tested and complies with BS-5839 part 4:! 988 for control and indicating equipment. Full range of devices for hazardous areas available.All detectors and manual callpoints have a unique address. Multiple microprocessor control for increased reliability.
Monitoring of all field devices and alarm path. Optional programmable control outputs, in modules of 16 to a maximum of 240 outputs. RS232C and 20 mA current loop interface for data communication to remote text or graphics displays, repeaters or building management systems. 2 x 40 character fluorescent dot-matrix alphanumeric display for clarity. Detector or loop disablement with timed automatic or manual restoration. Historical event logging.
On optional printer, all; events and changes of status are printed. Day/night alarm organisation facility. Self-diagnosis of "fault" condition. Sensitivity of all devices easily examined. Reduces maintenance costs due to inherent reliability. Tested and complies with BS-5839 part 4:! 988 for control and indicating equipment. Full range of devices for hazardous areas available.
BLOCK DIAGRAM
M82.2319.01
SALES SHEET BS-100
BS100/10/A/E
OPERATORS HANDBOOK
BS100/FBE 1
INSTALLATION HANDBOOK
BS100/04/A/E
COMMISSIONING HANDBOOK
BS100/EBE
BATTERY (2 X 12 V 14Ah )
A512/16G5
DATA SHEET RELAY RS-30 / RS-32
BU-4982 / BU-5083
DIM. SKETCH BS-100 CABINET
BU-6202
ARRANGEMENT DRAWINGS
M82-2319..02
CONNECTION DIAGRAMS
M82-2319..03-08
SUB DISPLAY BU-70
BU-4624
P-BU70/CCE
BU70/04,05,06BE
AUTOMATIC DETECTORS:
BH-31.BJ-31, BE-30, BWP-40B
BN-33A/S610
MANUAL CALL POINTS
BF-31.BF-35
EX-DETECTOR
P-DET/Ex/RAE
BZ-32/1
BJ-31/EX
DOOR HOLDING MAGNET
GT-50
BELLS
0-5312/5319/5310/5311
AIR HORN
0-5305
8
DATA LISTING
S3-1282
AUTRONICA REPRESENTANTIVES
016_Fire_ alarms_ system_ BS-100-2_-_Documentation.pdf
Download [19 KB]
Fire Alarm System- Diagrams - Cornel Barbu [2014, PDF]
JRC NAVTEX Receiver Instruction Manual NCR-333 - JRC [2013, PDF]
DataChief C20 - Alarm and monitoring system with process control and power management (Instruction…
Furuno Felcom 18 Inmarsat-C Operators Manual - Furuno [2012, PDF]
Furuno Felcom 12 Inmarsat-C Operators Manual - Furuno [2003, PDF]
Furuno Felcom 19 Inmarsat-C Operators Manual - Furuno [2012, PDF]
Furuno Felcom 15 Inmarsat-C Operators Manual - Furuno [2009, PDF]
ABS - Guide for Dynamic Positioning Systems - ABS [2021, PDF]
The time now is: Today 16:14
