Bulldozer ®   13-Sep-2014 16:48
The Tufmon MEV282…Oil Mist Detector/Manual Instruction
Number of pages: 29
Description: This compact series of Oil Mist Detectors can be easily mounted into the engine and connected to the control system. The unit can be delivered with and without creakcase pressure monitoring. The system needs a voltage of 24VDC and an "engine is running" contact. The unit monitors the actual oil mist concentration or the crankcase pressure and is set at a limit value which relay output with warning and danger alarm. As the signal output is 4-20 mA. which can be provided to a measured quantity of the pressure available. The unit has relays for the functions readiness for operation, pre-alarm and danger alarm, which either stops the engine or slows it down to idle speed. False alarms caused by condensation and evaporation of water vapour at a tolerable content of moisture in the lube oil is avoided by a direct heating at he measuring optical system, The major benefit of this system is that there is no need of piping and installation is easy.
omd
Download [4 KB]
ASHOK   28-Nov-2014 05:36
THANK...YOU....BUT HOW TO CALIBRATE THE OMD MEV282
Sperry Marine NAVITWIN IV Heading Management System Operation, Installation and Service Manual - Nor...
Hyundai Intelligent Watch Monitoring System HiWMS-PE Instruction Manual - Hyundai Heavy Industries C...
Kidde Graviner Mk 6 Oil mist detector / Installation, Operation and maintenance manual 59812-120 [20...
Digital Temperature Micro-controller X Model: PXZ - Fuji Electric/ Instruction and Operation Manuals...
RM22 / RM35 Control and Monitoring Relays - DarrenChew [2022, PDF]
JRC Doppler Sonar Instruction Manual JLN-550 - JRC [2013, PDF]
The time now is: Today 23:44
