twicer ®   27-Jan-2024 11:43
Ballast Water Management Plan [model]
Year: 2023
Author: Lloyd's Register and IMO
Genre: Other
Format: DOC/PDF
Pages count: Multiple
Description: Having an approved ballast water management plan (BWMP) onboard is a requirement of the BWM Convention (reg. B-1). LR can assist with approval of ballast water management plans (BWMP). Model BWMPs can be found in the resources section below, which can be used by operators as a template to create their ship-specific plan.
This Plan is written in accordance with the requirements of regulation B-1 of the International Convention for the Control and Management of Ships’ Ballast Water and Sediments, 2004 (the BWM Convention) taking into account the associated guidelines.
The purpose of the Plan is to meet the requirements for the control and management of ship’s ballast water and sediments in accordance with IMO Resolution MEPC 127(53) – Guidelines for Ballast Water Management and the Development of Ballast Water Management Plans (G4), as amended. It provides standard operational guidance for the planning and management of ships’ ballast water and sediments.
This Plan may be inspected on request by an authorised authority.
It is the Owner/Operator’s or Master’s responsibility to regularly review the Plan and ensure that the information it contains is accurate and up-to-date.
Multiple. See "FileList" below.
File Listing For: [*** \Ballast Water Management Plan] on 27-Jan-24
Model_Ballast_Water_Management_Plan_November_2023_D_1_D_2.docx [476 KB]
Model_Ballast_Water_Management_Plan_November_2023_D_2_.docx [453 KB]
BWM infographic.pdf [4 MB]
BWM.2_Circ.62_Guidance_on_contingency_measures_under_the_BWM_Convention.pdf [21 KB]
BWM.2_Circ.66_Rev.4_Unified_interpretations_to_the_BWM_Convention.pdf [135 KB]
BWM.2_Circ.80_Guidance_on_ballast_water_record_keeping_and_reporting.pdf [480 KB]
FAQ - Implementing the Ballast Water Management Convention.pdf [245 KB]
Guidance_on_Ballast_Water_Management_System_Commissioning_Testing.pdf [268 KB]
lrs-model_ballast_water_management_plan-january_2014.pdf [301 KB]
LR_s_National_Ballast_Water_Management_Requirements_22.03.19.pdf [813 KB]
MEPC.370_80_amendments to the guidelines for BWM and development of BWM plans.pdf [1 MB]
MEPC.371_80_amendments to the 2017 guidelines for BW exchange.pdf [1 MB]
Ballast Water Management: Ballast Water Management Plans & Ballast Water Record Books - Lloyd’s Regi...
Ballast Water Management Plan DNV template - DNV [2017, PDF]
Model Ballast Water Management Plan - Lloyd’s Register [2020, docx]
Model Ballast Water Record Book - Lloyd’s Register [2024, PDF, DOCx]
Ballast Water Management Plan [template] - ABS [202x, PDF]
Ballast Water Management Record Book requirements - DBS [2022, PDF]
Guide for Ballast Water Treatment - ABS [2019, PDF]
Guide for Ballast Water Treatment - ABS [2022, PDF]
Ballast Water Management for Yachts - ABS [201x, PDF]
  • Topic closed
The time now is: Today 22:52
