paolina_3 ®   22-Mar-2020 18:04
Samson Technical Bulletin
Year: 2018
Author: Samson rope Inc
Publisher: Samson Rope
Pages count: 140
Description: The use of rope involves different levels and modes of tension, bending, friction, and mechanical damage, as well as a wide range of environmental variables such as temperature and chemical exposure. Regardless of application, rope is exposed to service conditions and degradation. Maximizing rope performance and safety involves selecting the correct rope, using optimal handling during its use, and retiring it from service at some point.
A considerable amount of professional data sheets, divided by type of work (mooring, tug, recreational...), about rope handling, installation method, care, maintenance and end-for-ending procedures. Plus a use manual and a focus on HMPE mooring lines (slides)
Additional info: Folder with subdirectories
HMPE Mooring Lines.pdf
Rope_Users_Manual.pdf
\Miscellaneous\
tb_dpx_innovative-fiber-tech.pdf
tb_hmpe_post_production_process.pdf
tb_hmpe-ropes_design-vs-performance.pdf
tb_how-cold-can-you-go.pdf
tb_understanding-creep.pdf
\Mooring\
mp-1_performance_results.pdf
tb_coeffecient_of_friction.pdf
tb_handling-techniques-for-8strand-on-hbitts.pdf
tb_hmpe-ropes-and-chocks_closed-vs-roller.pdf
tb_inspection-retirement-pocket-guide.pdf
tb_mixed-moorings.pdf
tb_retrofitting.pdf
tb_rope-measurement.pdf
tb_surface-prep-for-synthetic-ropes.pdf
tb_tanker-mooring-in-hot-climates.pdf
tb_tension_fatigue_testing.pdf
type_approvals_and_product_certifications.pdf
\Recreational\
dblbrd_c2_stripping_cover_web.pdf
technical-bulletin-elastic-stiffness.pdf
\Tug\
tb_effect-of-twist-on-braided-rope_mar2012_web.pdf
tb_tug-messenger-line_apr2013_web.pdf
tb_vulcan-etops_sept2010_web.pdf
Technical Bulletin
Download [22 KB]
SAMSON Rope Catalogue - SamsonRope [2011, PDF]
Samson Splicing - Samson rope Inc [2012, PDF]
Effective Mooring [PDF]
Handbook of Fibre Rope Technology - H A McKenna, et al. [2004, PDF]
New England Ropes - Splicing Guide - Unknown [2011, PDF]
Installation and Inspection Manual For Synthetic Fiber Mooring Ropes (8, 12 & 24 strands) - D.…
Mooring Equipment Guidelines (MEG4) - Oil Companies International Marine Forum (OCIMF) [2018, PDF]
Wire Ropes Tension, Endurance, Reliability, 2nd Edition - Klaus Feyrer [2015, PDF]
Single Point Mooring Maintenance and Operations Guide (SMOG) - OCIMF [2015, PDF]
Lankhorst Ropes Catalogue - Maritime Division [2015, PDF]
The time now is: Today 14:21
