elias ®   06-May-2020 13:29
Anchoring systems and Procedures
Year: 2010
Author: OCIMF
Publisher: Witherby Seamanship
Edition: 2010
ISBN: 9781856094047
Pages count: 94
Description: As background to the development of this revised publication; concerns had been expressed, by OCIMF member companies and others, about an increase in the number of incidents involving anchor losses, windlass motor failures and associated personnel injuries. A review of third party anchoring incidents by an OCIMF member highlighted the following various issues. As a result of the review, it was agreed to revise and update the information contained in the original 1982 publication to assist in promulgating the lessons learnt from incidents, to provide improved information on anchoring practices and to recognise advances made in anchor systems in the intervening years. In particular, this publication highlights the design capabilities and limitations of anchoring systems and equipment with the aim of enhancing the safety of operations.
The scope of this publication addresses anchoring systems and procedures that are applicable to all vessel types, irrespective of their size.
Additional info: Screenshots of Ebook Aplication
List of Figures
List of Tables
Glossary of Terms and Abbreviations
Bibliography
Section1
Purpose and Scope
Section 2
Issues Associated with Anchoring Systems and Procedures
Section 3
General Description of Anchoring Systems
3.1 Anchoring System
3.1.1 Basic Equipment Arrangement
3.1.2 Safety Aspects
3.1.3 Limitations of the Anchoring System
3.2 Anchors
3.3 Chain Cable
3.4 Hawse Pipe
3.5 Anchor Lashing
3.6 Chain Stopper
3.7 Windlass
3.7.1 General
3.7.2 Cable Lifter
3.7.3 Windlass Gears and Clutches
3.7.4 Stripper Bar
3.7.5 Windlass Brake Systems
3.7.5.1 Band Brake
3.7.5.2 Disc Brake
3.7.5.3 Brake Drum and Disc Material
3.7.5.4 Hydraulically Assisted Brakes
3.8 Drive Units
3.8.1 High Pressure Hydraulic Systems
3.8.1.1 Protection Against Catastrophic Failure
3.8.2 Low Pressure Hydraulic Systems
3.8.3 Electric Systems
3.8.3.1 Frequency Controlled
3.8.3.2 Pole Changing
3.8.4 Steam
3.9 Windlass Control Systems
3.9.1 Remote Control
3.9.2 Chain Counters
3.10 Spurling Pipe and Chain Locker
Section 4
Design Considerations
4.1 Design Standard
4.2 Design Philosophy of Anchoring Equipment
4.3 Environmental Forces Acting on a Ship at Anchor
4.4 Anchors
4.4.1 Anchor Construction
4.4.2 Types of Anchor and Stowage
4.4.3 Holding Power of Anchors
4.5 Chain Cable
4.5.1 Length of Chain Cable
4.5.2 Material
4.5.3 Cable Strength
4.5.4 Bitter End
4.6 Chain Stopper
4.7 Windlass
4.7.1 Drive Units for Windlasses
4.8 Testing of Anchor Equipment and Systems
4.8.1 Anchor
4.8.2 Chain Cable
4.8.3 Windlass
4.8.4 Sea Trials
4.9 Interface Between Ship Structure and Anchoring Equipment
4.10 Arrangement of Equipment
4.10.1 Anchor Stowage and Hawse Pipe
4.10.2 Chain Lockers and Spurling Pipes
4.10.3 Access, Safety and Security
4.11 Additional Equipment
4.11.1 Cable Tension Monitoring System
4.11.2 Chain Counters and Speed Measurement
4.11.3 Remote Control Options
4.11.4 CCTV Monitoring Systems
Section 5
Operational Procedures
5.1 Anchoring Procedures
5.1.1 General
5.1.2 Preparation for Anchoring
5.1.3 Methods of Anchoring
5.1.4 Commonly Used Anchoring Procedures
5.1.5 Conventional Buoy Moorings
5.2 Maintaining an Anchor Watch
5.2.1 Watchkeeping Responsibilities
5.2.2 Securing the Cable at Anchor
5.3 Getting Underway
5.3.1 Avoiding Damage to the Anchor System
5.3.2 Emergency Recovery of Anchor and Cable
5.4 Use of Anchors in an Emergency
Section 6
Maintenance Issues
6.1 Routine Maintenance
6.1.1 Inspection
6.1.2 Lubrication
6.1.3 Flexible Hoses
6.1.4 Windlass Components
6.1.5 Windlass Drum Brakes
6.1.6 Chain Stopper
6.1.7 Chain Cable
6.2 Surveys and Inspections During Refit
6.2.1 Class Survey Procedures
6.2.2 Ranging and Inspection of Cable
6.2.3 Kenter Shackle
6.2.4 ‘D’ Shackle
6.2.5 Anchor Swivels
6.2.6 Anchors
6.2.7 Brakes
Appendices
A An Example of Typical Planned Maintenance Activities
B An Example of Typical Refit Inspection, Survey and Maintenance Activities
C Example Certification for Anchor Chain Cable and Chain Cable Fittings
Anchoring Systems and Procedures.pdf
magicbigbear   22-Nov-2021 08:05
I hope I can find the reasons for windlass motor failure during anchoring operation in this book especially in heavy weather.
zcg   17-Dec-2024 06:22
elias, would like to check the constant of anchor chain diameter.
suto   21-Apr-2025 04:46
IS wonderful ! thanks ! I've been doing this caculate lately, and you saved me !
Mooring Equipment Guidelines (MEG4) - Oil Companies International Marine Forum (OCIMF) [2018, PDF]
Estimating The Environmental Loads On Anchoring Systems - OCIMF [2010, PDF]
The Pocket Book of Anchoring - Captain Michael Lloyd [2009, PDF]
Effective Mooring [PDF]
Tank vessel Management and Self Assessment TMSA2 (2-nd edition) - OCIMF [2008, PDF]
Rickmers Standard for Stowage and Securing of Project Cargo - Rickmers-Linie GmbH & Cie. KG…
Offshore Engineering: An Introduction - 2nd Edition - Angus Mather [2000, PDF]
The Standard Club - Anchoring - Special Edition - Standard Club [2000, PDF]
Recommendations for Oil and Chemical Tanker Manifolds - Oil Companies International Marine Forum…
The time now is: Today 14:19
